Question about Samsung SGH-E251 Mobile Phone - Black
My phone keep on switching off
There isn't battery problem
    Brigadier General:
  • 7,752 Answers
Have the firmware reflash on the phone.........take the phone to a mobile service center and have your phone flash.....
Posted on Mar 12, 2009
Phone wont hold charge keep cutting off
Hello, either your charger isn;t working or your battery is bad, replace or take in for repair.
Mar 04, 2014 | tracfone.com
Samsung galaxy s2 gti9000 past drained even the phone is in off mode.they consume battery when it's off
If the phone is powered off it may consume a small amount of battery to keep your settings but shouldn't be much. There might be a sleep mode that makes the phone look like it's off but really isn't and that will drain your battery
Nov 09, 2012 | Samsung Galaxy S GTI9000 Smartphone
Starter switch burning out
I would check the relay first and make sure there isn't a corrosion build up there. An amp meter would help to troubleshoot this problem, looking for large amperage draws to the switch.
May 29, 2012 | Polaris ATV
What do u do when your phone won't charge even
charge your battery on another phone and then place your battery in your phone and switch on your phone and connect the charger to it if still it isn't charging then check your charger and if the charger is ok then you need to repair your phone manually or by taking it to authorized dealer
Apr 25, 2012 | Cell Phones
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Hi, during a software upgrade, my Nokia 6303 has completely died. The battery is fine. I can't switch it on and if I plug in the USB it isn't recognised. Any ideas? Thanks, Chris
Hi Chris, If you havent already done this, remove the battery from the phone completely, then put it back in after waiting a few seconds. See if this will reset it.
Aug 01, 2011 | Nokia 6303 Cell Phone
The mobile switching off & the bettery isn't low
I think your battery is loosen that's why it turns off even your not turning it off..Try to put a small paper on the battery case cover so that it put a little pressure to the battery so it will not loosen and to avoid untimely shutting off of your cellphone..Hope it will help you.
Jul 11, 2011 | Samsung Star GT-S5233 Cell Phone
My cell phone keeps shutting off on its own, and not turning back on, on its own. it is fully charged and i've tried taking the battery out and blowing it off, but it keeps doing this.
Check that the power button isn't stuck partially depressed. If that isn't it, you've got issues inside the phone that are going to require qualified service, or an internally damaged battery.
Jul 06, 2011 | Cell Phones
My nokia 3100c mobile switch off automatically.. and after i switch on its blinks 3 times and get switch off.... and ...
it means ur software is dead now try this
while turning on quickly remove ur battery try & try it again & again if this isn't working keep *,3,CALLKEY,VOL UP KEY pressed
May 14, 2011 | Nokia 3110 Cellular Phone
When i switch the phone on it goes to the homescreen and before i can press anything it reboots straightaway, i have tried taking out the sd card and sim card and still doesnt do anythin, it will...
Sounds like a software problem to me. take out your battery, and wait like a minute. Put the battery back in. Plug the phone into the charger. While it's charging, turn it on. Hopefully, you have enough time to do the next step: Dial *288 and press the number 1 when you hear the voice prompt you to. By doing this, you are resetting your phone. If this doesn't help, then I'm afraid there probably isn't anything you can do without bringing the phone to your provider's nearest store location. If it isn't due to water damage, they'll probably replace the phone for free. Hope this helps!
Please rate my solution!
- Frankie
May 07, 2011 | Samsung SGH-U900 Flipshot Cellular Phone
Samsung SGH-E251 Mobile Phone - Black Logo
78 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
