Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Removing the Agitator on a G155 Hotpoint washing machine
3 Suggested Answers
SOURCE: Removing the Agitator on a G157 Hotpoint washing machine
fgdfgd
Posted on May 13, 2008
jsrock516
  • 5911 Answers
SOURCE: removing agitator
Sometimes small articles of clothing can manage to get between the inner spin basket and outer wash tub. This is NOT common, however. If this were the case the memory stick you mentioned, would end up lodged in the drain pump. There would be a noticeable noise from the impeller hitting it and it may cause the pump to fail, resulting in drainage problems. More than likely, its right where you suspect it is. To remove the agitator, do the following:
1. Remove the center cap or dispenser from the agitator.
2. Under the cap or dispenser is another plastic cap with a pull handle on it. Lift this cap out by pulling straight up, exposing the agitator mounting bolt.
3. Loosen the agitator bolt using a socket and ratchet. Once removed, grasp the entire agitator assembly by the bottom flanges and lift straight up. The entire agitator should come out.
NOTE: When reinstalling the agitator make sure you DO NOT overtighten the mounting bolt or it can cause damage to the agitator and restrict the movement. Good and "snug" is the rule of thumb.
Searspartsdirect.com has an excellent exploded view diagram of your agitator and components if you need a good reference. Just type in your COMPLETE model number and look under the "Agitator, Basket and Tub Parts" heading.
I hope you find what you're looking for and hope this helps you in some way. If you require additional assistance, please let me know.
Posted on Sep 26, 2008
I got the strap of my swimsuit stuck under the agitator of my Hotpoint washing machine. I removed the top layer of the agitator, but don't know how to get under the part beneath it.
With the first part of the agitator off you now have to remove another cap off the top of what you now see. Under that will be a bolt that holds the whole bottom of the agitator on.
Feb 28, 2015 | Hotpoint Washing Machines
G155
You have to do it manually. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Sep 09, 2012 | Hotpoint Washing Machines
Can't remove agitator on hotpoint washer
I have this same model of Hotpoint washer. I pulled up on the agitator and that separated it from the hub. I removed the hub by loosening the bolt at the top of the hub with a socket wrench. I removed the hub after removing the bolt. I removed the long stringy fabric by unwinding it and lifting up. that's all there is to it. Really simple. Everything went back together very easily. Only hard part is lifting the agitator up with enough force to free it from the hub.
Aug 10, 2012 | Hotpoint Washing Machines
My hotpoint washer will spin but will not wash or rinse, the agitator makes a noise as it attempts to wash and then rinse. the spin seems to work fine
The agitator shaft has splines at its top which fit inside a splined area inside the agitator. Sometimes the splines in the agitator strip; then you would need a new agitator. If that is not the case the problem is within the mechanism. There is a repair kit available for that, but you need to take the mechanism out of the machine. I am assuming that you have the "direct drive" machine, recognizable by the pump sitting at the front, in the middle, under the tub. If you have the older, belt driven washer, please get back and I will explain.
May 09, 2011 | Hotpoint Washing Machines
A sweatshirt cord is wrapped around my HotPoint top load washing machine. The machine is 18 years old. Can I pull off the agitator to retreive the string?
If it's wrapped around up underneath the agitator you can.
Have you tried just figuring out which way it was wrapped?
Keep a can of WD-40 handy.
Jan 29, 2009 | Hotpoint VBXR1090B Top Load Washer
I got the strings of my sweat pants stuck under the agitator of my old Hotpoint washing machines. How can I remove the agitator to untangle it?
At the top of the agitator has a cap get a flat screw driver and pry up and turn. When it comes off there is a nut you have to take off.Then pull up on the agitator..
Jan 15, 2009 | Hotpoint VBXR1090D Top Load Washer
The aggitator in my Hotpoint Washer just came off while it was washing clothes. I thought I had it back in but it came back off on the next wash. How do I get it to stay?
hi .sometimes the problem is with the bell which is located under the agitator. its a part that holds the agitator down. or the agitator its self. the bell is cheap to replace first. thanks the appliance doc please rate me thanks
Oct 01, 2008 | Hotpoint Washing Machines
Some models have a bolt towards the bottom of the outside of the agitator, depending on model. If it has one, take out out and you'll have to yank on it VERY hard to get of off (you'll most likely lift the machine off of the ground a few times in the process!)
If the bolt isn't there, its under the top cap of the agitator "somewhere". You'll still have to yank up on the silly thing to get it off after taking the bolt out.
Jan 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint washer
Two types of Hotpoints had two different ways of removing the agitator. One had a pop off top that when you removed it, you can remove the center bolt, the remove the agitator. Another one you had to put your fingers under the agitator and pull straight up to unclip the agitator. Good Luck!!! Jim
Sep 04, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
