Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
Trimmer will not work. Battery charger says ready
How do I know what needs to be replaced?
Check the charger with a voltmeter to be sure it's working. If not replace it. If it is, replace the battery.
However, be aware of pricing. Sometimes it's better to just replace the whole system.
Aug 31, 2016 | Remington BHT2000 Hair Trimmer
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
Aug 08, 2016 | Ryobi 40-Volt Lithium-Ion Cordless String...
Troubleshoot/Repair Remington MB-1000 Beard Trimmer
If you leave the batteries in the charger with the mains power turned off then the batteries are probably being drained by the charger. Get new batteries and when flat (only flat not just used or part flat) recharge fully then remove from the charger unit. Rechargeable batteries have a habit of developing a memory as if you recharge a part charged battery then it will only recharge to that flat point
May 30, 2013 | Remington MB-1000 Professional Beard and...
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
Battery charger on a Worx Gt Trimmer Battery is blinking red what is the problem
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
Feb 21, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
How do I attach the machine to the wall charger when the protective cover prevents it fitting properly to the wall. Sticks out below putting it at an angle to not fit into the charger. Do I have to remove...
If you can't make the charger fit while the battery is attached to the trimmer, you can remove the battery pack (the whole black handle assembly) by pressing in the two orange tabs (one on each side) and sliding the battery pack forward off of the trimmer. Then you can plug the charger in and charge the battery wherever you want. It can be a struggle to remove the battery pack, but it does come off.
Hope that helps.
Jul 17, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Charger for B+D Cordless String Trimmer Model #783541new charger or toss?
There is another way. Use the lighter outlet in your car. Adapt a cord to accommidate the connections.
Oct 20, 2008 | Garden
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
29 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
