Question about Refrigerators
Making a loud noise
Cant be sure but maybe some sort of fan. sound is coming from the bottom of the unit. only started recently there is some dust down there but before i started shoving anything in there thought i see if there were some sort of trouble shooting guide. it has been acting funny lately the door will not stay closed, the bulb went out inside and i replaced it and it would'nt come back on, now this noise which is annoying. please any ideas or anything would help!
  • 400 Answers
Check if your fridge has a condenser fanmotor, it could be bad and needs replacing. Use a vacuum cleaner to clean the dust off the condenser coils.
Posted on Mar 12, 2009
Loud noise under refrigerator
it's a condenser fan, it's located on the bottom ,,at the back of the frig
unplug it first from the wall, & vaccum under neath bottom & around the fan,,then you need to see if the fan came loose from the shaft & if so tighten & also make sure nothing is caught in the fan...
Aug 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Excessive fan noise at start up
Check if fans are covered wit dust or wires block the airflow,
if stil u get the sound then you have to replace the fans
Jul 10, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Xbox 360 is loud - sounds like a loud fan motor. How can I make it run quietly?
You can try installing the game you want to play on the Xbox 360 Hard Disk, which reduces the motor noise to an extent, however there is no permanent way to fix the loud fan motor noise while playing the game with the disk in the drive.
Make sure you keep your Xbox 360 unit well ventilated, ensure it does not gather dust near the small vents and openings on the unit.
Regards
KreativeGeek
Dec 26, 2009 | Microsoft Xbox 360 Console
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud rattleing sound
If this AC is a thru walled, since it is new it is better to inquire to the people where you buy this unit, for this type of problem. They must have some authorized repair man/shop or, use its product warranty.
The problem could be also uneven placement of its base. This could maybe hitting the fan guard, some loose connection or some foreign object left that's hitting something inside.
Jul 31, 2009 | Kenmore 75085 Air Conditioner
Noise from hitachi 42PD5000
The noise is coming from one of the plasma driver boards. There are 2 inside the set. These are essentially power supplies for the plasma itself and contain many capacitors. The noise you hear is some oscillation inside a cap or two. This is an indication that one or more components have drifted from their rated value. While the set will continue to work for a while, that board should be replaced. If the board fails, 1/2 of the picture will be blank or the set will not start at all. Call around to get the cost of that board. Please note that continued use of the set WILL NOT cause any harm. This is an annoyance only at this point.
Dan
Apr 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Growling noise coming from back of fridge
Try lubricating all fan bearings that you can get to. Make sure fan blades not hitting any thing.
Aug 27, 2017 | LG LRBN22514ST Bottom Freezer Refrigerator
Loud fan noise near bottom of freezer on my kenmore elite
There is a fan down on the bottom of your unit it sounds to me like the fan is making the noise as the bearings are getting dry. You should be able to move the unit out from the wall and get behind and look at the fan right next to the compressor. let me know how it goes. ken
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
