Question about Goodman CKL60AR60 Air Conditioner
Outside united is blown the small 3 amp fuse in furance
    Genius:
  • Goodman Master
  • 1,363 Answers
Shorted coil in outside contactor most likely.
Posted on Aug 12, 2015
Rudd model ukab-030jaz
You most likely have a small 3 or 5 amp fuse on the circuit board on the indoor unit that has blown. You should turn the power off at the main breaker panel and open the cover and very carefully look for a small blown fuse. It will look like one that you use in your car. Then if it is blown, replace it with the exact same size and rating.
Aug 17, 2017 | Heating & Cooling
Didn't cool and the fan on the outside unit is not turning
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Aug 24, 2011 | Goodman Heating & Cooling
I was replacing an old thermostat and for got to cut the power off to it, now it don't work at all..some one told me there was a fuse I could have blown by now cutting the power first..the heat pump is...
Hi Bill, go to the indoor unit and remove the panel. You will have a circuit board. It will have a 3 or 5 amp plug in type fuse, like an auto fuse. Its more then likely blown. Replace it and you should be back on line.
Sincerely,
Shastalaker7
A/C Contractor
Jun 06, 2011 | Heating & Cooling
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
Will not send water through the water solenoid valve and blows fuses in the furnace
Is this a small 3 or 5 amp fuse it is blowing at the furance. My assumption it is. If this fuse is blowing right away, then this is a direct short. The solinoid valve needs to be replaced. The valve has a direct ground to casing short. Replace the valve and the furance will not blow fuses anymore.
Jan 24, 2011 | Aprilaire 550 Humidifier
I have a 2006 Keystone travel trailer that has a remote control that opperates both the air conditioner and the furance for some reason I can not get the unit to work in either function with the remote or...
Check all 12 volt fuses in panel, as well as make sure breaker is on that powers unit. Also if you pull face off wall thermostat, you may have glass fuses in there & possible one or more has blown & will need to be replaced. Do you hear any clicking when you operate thermostat manually from wall?
Sep 12, 2009 | Heating & Cooling
NO POWER TO DOWNSTAIRS FURNACE NO FAN NO AC ??
what brand? most likely fuse is blown on furnace control board if there is no fuse then transformer could be blown sounds like a short in system look for bare wires at ac unit small wire outside especially if your have dogs around ac unit
Jun 24, 2009 | Heating & Cooling
Keeps blowing the fuse.
In more rare scenarios the 24v activated fan relay that is soldered to the circuit board can cause this same problem. I agree with Therinnaiguy, If the fuse is blown 90+% of the time there is a short in the 24 volt control system.
Jun 09, 2008 | Goodman GMS90703BXA Heater
Goodman CKL60AR60 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
