Question about Cuisinart Blend & Cook Soup Maker
Flashing red light on cuisinart blend and cook
Flashing light. Blender won't work
  • 3 Answers
SOURCE: Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
Posted on Aug 20, 2008
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
co7196
  • 3433 Answers
SOURCE: the lights on my cuisinart blender come on but the
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Posted on Sep 19, 2009
  • 16 Answers
SOURCE: Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Posted on Oct 11, 2009
SOURCE: My cuisinart blender doesn't work.
Pretty much that is what happened to me. I found that the motor has 2 "thermal cut-offs" (SEFUSE 113oC). If the motor heats up even a little, these babies kill your blender. They are thermal fuses. Once they blow, it is over until they are replaced. To fix this, the motor must be removed. The spline gismo on top of the blender unscrews with reversed threads. I suggest unsoldering the lead wires from the power supply board, and replacing when done. The cut-offs are inside the taped on white cloth insulation on the top of the field magnets near the brush assemblies on both sides. I replaced them (both were blown) with 2 of NTE8242 ($1.60 each, 240oC 15A). These are way too hot, but that is what I had on hand. I thought that the electronics were defective at first, and I replaced the entire board assembly with a small/cheap ceiling fan wall switch /speed controller from the hardware store (600W 5A) for $10. The root cause of all of this is that the motor fan is not working. The airflow is blocked by base. I put small extenders on the feet and now there is much more airflow. Only time will tell if this is an effective fix. It appears to me that the device my have started out "nice" when it was designed, but cheapened (probably by middle managers taking bonuses for "improving" the design) many times. The fuse is gone, the case is plastic, etc. It really makes me wonder how it got past UL approval.
Posted on Sep 05, 2010
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Blender not working
Check power to the switch, and from there to the motor.
Jul 11, 2015 | Conair Cuisinart Sbc-1000 Soup Maker And...
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
Ginny's blender lights keep flashing
you have to have the top part on before you turn on the blender
Sep 09, 2012 | Blenders
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
I tried to blend large piece of the frozen mango. It won't move and I continue trying . I smell little burned and the machine wont move again.
It sounds as if the motor has burned out. You may need to purchase a new blender or send it to the manufacture for repair if it's still under warranty.
Jul 14, 2011 | Cuisinart Blenders
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Cuisinart Blend & Cook Soup Maker Logo
50 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
