Question about Garden
Put clutch cable on bolens tiller 21a-250h065
Need to know how to replace clutch cable
  • 708 Answers
SOURCE: Need manual or details for Yard Machine 21A-333A129
Go to http://manuals.mtdproducts.com then click public site.
Posted on Mar 28, 2009
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
emissionwiz
  • 80531 Answers
SOURCE: Troy bilt Bronco tiller Model#
Recheck the pulleys, sand the pulley grooves until they are rough for max grip w/80 grit and do a careful pulley alignment check with a straight edge, don't just eyeball it, then make sure the belts are not to loose, about 1/2" at center run of belt is good enough,
Posted on Oct 19, 2010
How do I replace the clutch cable on a 2003 Kia Rio?
they are really easy to do the end just goes into a little hole then it just goes agains the stop inside the hole they are really easy to do , look on youtube you may find your answer there
Jan 19, 2015 | 2003 Kia Rio
I am replacing a clutch cable on a 1980 xlh sportster and I don't know wether it needs to be in a specific gear to do the job !
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Sportster Clutch Cable Replace
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 24, 2013 | 1979 Harley Davidson XLH 1000 Sportster
NEED TO REPLACE MY CLUTCH CABLE ON MY 1989 YAMAHA FZR 600
Hi, Gregory love that name, sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Help replacing my clutch cable The FZR Forum
HowTo Motorcycle Clutch Cable Replacement Yamaha R1 HD
https://www.tradebit.com/filedetail.php/269137237-yamaha-fzr600-1989-1999-factory-service-repair-manual
OEM parts for Yamaha
http://www.fzrarchives.com/fzr600/600_manual/1999fzr600r.pdf
Feb 10, 2013 | 1989 Yamaha FZR 600
Need to know how to replaces clutch my 2001 5 speed manual pontiac sunfire car
Unhook positive battery cable, the clutch cable or hydraulic slave cylinder to get the transaxle ready for removal. Secure your car in a safe position. Jack up the front. Stabilize engine with a jack below the oil pan. Remove the transaxle. Separate engine from the transaxle. Push transaxle away from the engine. Disengage the bolts around the pressure plate. Take it and the clutch disc out. Follow instructions for replacing the clutch. Take flywheel and old seal out. Install a new seal. Done! Know how to repair cars by http;//www.obd2express.co.uk
Oct 23, 2012 | Cars & Trucks
How do I replace my clutch cable on a 98 dyna low rider
You will have to replace the entire cable. Also buy a transmission side cover gasket because you have to take the cover off to replace the cable.
Aug 12, 2012 | Harley Davidson FXDL Dyna Low Rider...
I drive a toyota corolla 2007 face lift model. My car has 61k mileage on it. Oil levels are fine and i done a 60k service on my car. But my clutch is extremely hard. Its the hardest clutch i ever felt. i...
If it has a cable,it may need lubed if it is hydraulic type, it may have binding likage in the bell housing! I,d rather think it has a cable. DOES IT HAVE 2 FLUID CHECKS UNDER THE HOOD,ONE BIGGER ONE, AND ONE SMALLER OR JUST ONE BIG DOUBLE LOOKING CAP, OR LONGER LOOKING RESERVOIR ON A CYLINDER WITH FRONT AND REAR TUBES! THIS IS FOR THE BRAKES! If you see one more then it is for the clutch.
Sep 06, 2010 | 2007 Toyota Corolla
Clutch pedal goes all the way down some bracket looking thing broke underneath that the cable goes though what is it help i know i am not making any sense
the clutch pedal box needs replacing and also a cable. the cable has become stiff over time therefore putting extra strain on the bracket when the clutch is depressed hence now it is broken.
Aug 06, 2009 | Mitsubishi Mighty Max Cars & Trucks
Need to replace clutch cable on a 2002 H-D Dyna, FXD. Are there "exploded" views of the clutch cable assembly showing how to remove and replace the cable from the clutch? The cable broke at the hand-grip...
To replace the cable, you are going to have to remove the cover on the end of the right side of the transmission. Just follow the cable and see where it goes into transmission. You may have to remove exhaust pipes to do this. The threaded cable end screws into this cover. If the handlebars are the stock type bars, simply replace with a stock cable. If the bars have been changed, you'll have to match the overall cable length to get the right cable.
Jun 15, 2009 | 2001 Harley Davidson FXDXT Dyna Super...
Can't shift into gear
If the clutch lever is very easy to pull back (no tension) your cable is broke, if not you need to adjust the clutch. You might want to check at your local library to find a repair manual for your bike. It will show you what you need to know, replacing cable or adjusting clutch.
May 20, 2009 | 1986 Yamaha FJ 1100
Clutch slipping
first i would try adjusting the clutch cable because commonly people with think that they're clutch is going out when really just the cable has gotten stretched....try adjusting that first and if that works then you should be fine for another couple thousand miles but if you want to not have to worry bout it for awhile i would just replace teh clutch assembly....usually ranges from $200 to $450 depending on the clutch set and the mechanic that does the work for you. Let me know what happens. :)
Oct 01, 2008 | 1990 Peugeot 405
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
