Pokemon Emerald
EMERALD ONLY! REGI GUIDE! EVERYTHING you need and how to do it:
1) Relicanth, 2) Wailord, 3) Dive, 4) Surf, 5) Rock Smash, 6) Dig, 7) Flash, 8) Fly*
(BRING 60+ Ultra Balls/ 30+ Timer Balls/ Pokemon levels 40-47 with Status effects like: Sleep/Paralyze)
1) Relicanth is found only underwater outside Sootopolis City (Route 126 is the best, 124 is the only other option)
2) Wailmer is found by fishing with a Super Rod on Route 129. You will
get the Super Rod from a sailor living near the Space Center in
Mossdeep. Surf and while surfing, use the rod. You may not get a
Wailmer on the first try but keep on trying. When you get the Wailmer,
evolve it. It evolves at Level 40. If it is already at Lv. 40 or over,
evolve it one more level and it will evolve. It's pretty common outside
of Lillycove City.
3 - 5) You must have had these to get through the game.
6) Dig. There is only one dig TM in the game. It is given
to you by a girl in Route 114. Just off Fallabor Town. She is next to a
cave inside her house. She says that her brother is the Fossil Maniac
and she gives you the TM Dig. Dig, is a TM. Dig can only be used once,.
You can still get dig elsewhere; Trapinch learns Dig at level 41 and
Nincada at level 45. Or trade a Diglett from Diglett's Cave from
FireRed/LeafGreen.
7) Flash is not optional. You MUST have it to unlock Registeel. Without it, you can still unlock the other two, but, you need it to unlock Registeel.
8) Fly is optional. But, without it you would have to Surf to everywhere you want to go. It is highly recommended.
Onward to the Regi's!
REMEMBER: If you happen to mess up, no biggy, fly back to Pacilog Town and try again.
First, fly to Pacifilog Town, Surf west, go NEAR the currents but NOT
in them, yet. What we're trying to do is to stay as low as possible to
the currents. Go to the lowest point, and start surfing. If done
correctly, you will now be facing a fisherman. If not previously done,
he will challange you to a battle. Defeat him and walk down, to the
lowest point and surf. If done correctly, you will be facing a pair of
swimmers. Go past them and touch the very lowest part of the current.
You will land on a shallow part of Water. From here, go to the lowest
part and go again.
From here, you will be taken to a shallow part of Water. Notice; part
is on Route 133, part is on Route 134. Once here, walk to the left as
much as possible (without leaving the shallow Water) and then walk down
as much as possible. You will now be at the bottom-left-hand corner.
Take two steps forward, turn left and surf. If properly calculated, you
will now be in currents, the currents will then take you to a patch of
still Water where you can dive. When you dive, go through the cave, you
will still be underwater. Follow the path and you will arrive at a rock
engraved with braille. When translated, the braille reads; GO UP HERE.
Be on this exact spot and surface. If done accordingly, you will now be
in the sealed Chamber.
In here, you will find ten rocks all engraved with braille. Go to the
back of the chamber, the braille reads; DIG HERE. Use the Pokemon that
has Dig and Dig there. A path to another room will open up. In this
room, there are six stones, they read;
1) IN THIS CAVE WE HAVE LIVED.
2) WE OWE ALL TO Pokemon.
3) BUT, WE SEALED THE Pokemon AWAY.
4) WE FEARED IT.
5) THOSE WITH COURAGE, THOSE WITH HOPE.
6) OPEN A DOOR. AN ETERNAL Pokemon AWAITS.
Go to the back of the room. More braille. It reads; FIRST COMES
WAILORD, LAST COMES RELICANTH. Put Wailord first in your party, and put
Relicanth last. Well, that's it. If you've done as said, the doors
would have opened. Exit the cave.
REGIROCK,
ABILITY; CLEAR BODY (Prevents ability reduction)
Met at Lv. 40, in DESERT RUINS.
Moves: CURSE, SUPERPOWER, ANCIENTPOWER, ROCK THROW
Fly to Lavaridge Town, go west (right) until you meet the desert. Go
in. To the bottom of the desert, you will see a rock with an opening.
go in. . Go to the back of the cave and read the braille. From the
braille, walk exactly like this;
LEFT, LEFT, DOWN, DOWN, THEN USE ROCK SMASH.
If you've done it correctly, a new opening will be revealed at the back of the cave. Go in. SAVE! Do not use your Masterball. Do not kill it. Capture it... NEXT!
REGICE
Met at Lv. 40, in ISLAND CAVE
Moves: ICY WIND, CURSE, SUPERPOWER, ANCIENTPOWER.
Fly to Petalburg City. Go west of the city and use surf. Stay to the
left and you will come to some trees, land go around the trees,
continue going down and you will find the cave. The braille at the back
reads: STAY CLOSE TO THE WALL. RUN AROUND ONE LAP.
So, in any direction, RUN around the cave without leaving the wall. If done correctly, the opening will be revealed. Go in. SAVE! Capture. Do not use your Masterball. Do not kill it!
Last one! REGISTEEL!
Met at Lv. 40, in ANCIENT TOMB
Moves: METAL CLAW, CURSE, SUPERPOWER, ANCIENTPOWER.
Here is where you need Flash. Fly to Lilycove. Go to the west. Continue
going west for a longish while until you can no longer go. Go up the
stairs, through the really tall Grass, up the stairs again. Guess what?
Go to the back of the room. The braille reads:
THOSE WHO INHERIT OUR WILL, SHINE IN THE MIDDLE. Walk four steps back and use flash. Go in. SAVE! Capture. Do not use your Masterball. Do not kill it
evolv what?
What do you mean?
