Question about Diesel Dz7183 Digital Time Frames Grey Rubber Mens Watch
How to set time
Had the battery changed, now I can't work out how to reset the time
  • Diesel Master
  • 18,424 Answers
Changed the batteries and now the main screen doesn't show anything. I even did the reset button in the back and changed the batteries again. The sensor works (LED Light blinks). How do I fix this
You said you pushed the reset button a couple of times...is it the one you have to press with a paper clip? you have to hold that button in for five seconds for the reset to take...not sure if you held it in or not...here's two links for the 2-page manual if that doesn't take care of it...
http://westcloxsource.com/usermanuals/70034IM1.pdf page 1
http://westcloxsource.com/usermanuals/70034IM2.pdf page 2
Nov 03, 2012 | Watches
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
I own a diesel dz7149 watch and can't figure out how to reset the time. i checked the company website but its not working, and i downloaded the pdf
Welcome to fixya. To set the time on a Diesel DZ 7133 watch please follow these steps: -You must have the T1 (Time 1) enable and NOT the T2 (Time 2).-To change between T1 and T2, click and hold the upper right button (C). -When you finally are on T1, click and hold the upper left button (A) and you are set to go!
-Click the lower left button (B) to scroll through various functions until you get to the 'set time' function.
Jul 22, 2011 | Watches
Trying to seth the date on my Timex Indiglo CR1216
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
Jul 07, 2011 | Timex 40131 Wristwatch
Just had a new battery installed in a fila wind master watch. the hr, min and sec hands are spinning and it goes through the start cycle. not able to stop this. also need instructions on how to set time....
Hi, According to your problem first make sure that the battery that you have changed is OK, or try another battery. Your watch need a factory reset. If normal factory reseting doesn't solve your problem then you have to repair the machine.
Jun 29, 2011 | Fila Watches
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
I have a Pulsar w861-x002. The battery went dead, so I took the watch to a jewelry store (that also sells Pulsar watches). They replaced the battery, but now the time/year/and everything else cannot be...
I replaced my battery too...same watch same ugly condition where you can't set time nor does the light work.
I do know what the problem is: there was an ultra small copperish spring...about 1/6 the size of the other little wire spring that you have to short with twizers to reset time. Anyway, I lost this part...and even if I found it, I wouldn't know where it goes. I came on-line to find where the missing part goes...but everyone has the same issue as me. any jeweler would loose this parts just like me...it's the master contact the enables power to all the side pushbuttons
Sep 15, 2010 | Watches
Silicon scientific atomic projection clock did no reset for daylight saving. Help
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
May 19, 2010 | Watches
Can't set the hour on my Aqualand Duplex
i followed the instructions on the Citizen website for a system reset and it worked. Unfortunately, the regular way of setting the digital hour does not. Maybe a technical problem? The movement number for the Aqualand duplex is C506.
1. unscrew the analog adjustment crown and pull one click
2. press and hold the other 3 buttons for 3 seconds and release.
3. push the analog crown back and adjust the digital time.
this is a system reset so you will have to set the date. You will lose your settings and your dives. good luck.
Mar 10, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Diesel Dz7183 Digital Time Frames Grey Rubber Mens Watch Logo
163 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
