Question about Husqvarna 6021P 21-Inch 149cc Kohler XT-6 Gas Powered 3-N-1 Push Lawn
Husqvarna push mower socket size for spark plug
3 Suggested Answers
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
Posted on Jul 20, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
What size socket wrench to change spark plug in husqvarna push mower
www.husqvarna.com/us/support/
Measure it by using an adjustable wrench and a tape measure.
Oct 12, 2014 | Husqvarna 675 hp 21" Honda Rear Bag Push...
What size husqvarna spark plug
BPMR's and RCJ's use 3/4" sockets
Jul 06, 2014 | Garden
How to change the spark plug on a Husqvarna 6021P 21 inch
I use a spark plug wrench or a deep socket and turn counter clockwise.
Jun 16, 2014 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
What spark plug do i need for a husquvrna 6021p
Your owner's manual calls for Spark Plug (Gap: .030"): Champion 8815
Your owner manual is online at: http://www.husqvarna.com/ddoc/HUSO/HUSO2010_USen/HUSO2010_USen__532433773.pdf
Your
Apr 09, 2014 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Spark plug keeps getting soot on it
an indication of running rich . check that the air filter is clean and not blocked-- check that the choke control is off after starting--check float level and operation of needle and seat.
Jun 20, 2013 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Riding Mowers
You may need a 'heli' coil or a larger Spark Plug, it seems that the vehicle at operating temperatures is building up too much pressure and pushing out your current sized plug! Same thing happened to a me! And if its too much pressure, there is a 'filter' that becomes restricted, easy check!
Hopes this helps!
Dr. Gene n Landrum, PhQ. Quantum
May 19, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
WHAT SIZE SPARK PLUG SOCKET TO USE
Depends on which size plug you are using. Hint, keep changing sockets until you find the one that fits. They are not metric.
There are three sizes of plug in normal use, 10mm, 14mm and 18mm. (They are identified by their thread size) The socket sizes for these are 5/8" (16mm) 13/16" (21mm) and 15/16" (24mm). However, many 14mm plugs (the most common size) have 5/8 hexagons, and many 18mm plugs have 13/16 hexagons!
May 20, 2012 | Garden
Husqvarna 6021P 21-Inch 149cc Kohler XT-6 Gas Powered 3-N-1 Push Lawn Logo
743 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
