My Averatec Series 2300 Laptop beeps every 70-85 seconds.
The battery light flashes from green to amber. Since it had been disconnected from electricity for several months, I assumed it simply needed to take several hours to resume normal voltage. I kept it on and plugged in for 8 hours with the lid closed (to keep the screen display off). However, it still beeps and flashes the same. How can I diagnose what the beeping means and what is the solution?
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Belkin Connect N150 Wireless Router...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Laptop battery charge indicator flashing amber and green
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the batter15.jpg light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
Apr 14, 2009 | Dell XPS M1710 2.33GHz Core 2 DUO T7600...
Toshiba satellite pro 4200 wont start,just 1 flashing amber light
I had a similar problem on SatPro6100. Mine was LSSSLSSL (10010001).
Thinking that the laptop was buggered I decided I would take it apart and have a look at the insides.
Whilst it was apart I also disconnected the BIOS battery.
Couldn't find anything that looked like it had burnt out so put it all back together again.
When I turned it on again the darn thing was working fine!!!
Go figure!!
The whole thing was apart for about 2 hours or so.
I don't know if it was removing the main battery and leaving it out for that time or whether it was resetting the BIOS (by disconnecting its battery) that fixed the problem.
Anyway, I have managed to get all my data off the laptop so not too worried if it screws up again.
I do however always disconnect the power source BEFORE shutting down the laptop and only reconnect it after I have pressed the on button. Seems to be working fine (for now!)
Hope that helps someone out there!
Mar 11, 2009 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
Computer does not turn on when I press the power button
do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Feb 26, 2009 | Averatec 2371 AMD Turion Notebook
I have an Averatec laptop, series 2300. While I was using it, it just shut down (immediate shut down) and wouldn't boot up again. I have removed battery, Let it charge overnight, and twice it has come...
Are you just running it from the battery? It sounds like you may have a motherboard problem. I would first put in my OS boot cd and see if it boots from the CD. Let me know if you don't know how to boot from CD. If it does boot from cd then run a chkdsk /r on your hard drive.
If that doesn't fix it I would see if the power supply is not working again are you running from the battery without power supply?
Thanks,
Henry
Aug 19, 2008 | Computers & Internet
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
