Question about HP Officejet 5610 All-In-One InkJet Printer
HP 5610 All-in-one won't print color
FIrst, everything in color didn't print at all.  Then we played with it and got the color stuff to print in black.  How do I get it to print the color things in color???
  • 60 Answers
If you look in your control panel on your computer and then look under printers, you can right-click on the printer that you are using and go to properties/settings. From there, make sure that the Black Print Ink Cartridge only option is not selected.  When you say you playsed with it and got it to print, did you modify the settings on the actual printer menu at all?
Posted on Mar 12, 2009
I have an hp officejet 5610 all-in-one and I replaced the tri-color print cartridge. However, when I tried to align the cartride, it failed. I have turned the printer on/off and now I no longer get the...
your color cartridge is not printing
get a new one or refill the old one
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
May 14, 2010 | HP Officejet 5610 All-In-One InkJet...
OFFICEJET 5610 COLOR AIO Printer: I have an hp 1530 that wont print in color after w...
Open HP solution center.
click on settings >>> Printer settings >>> click on Color tab..
select print in color. Click on OK.
Now try to print
May 07, 2010 | HP Officejet 5610 Color All-in-One Printer
Very slow printing - HP 5610 all in one
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP OfficeJet 5610 All In One alignment cartridges and no printing
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab101
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Problem with printing smoothly
Hi morshi. I found a potential solution to your problem with your 5610 printing vertical lines at HP.com:
Vertical black lines or streaks
It's hard to tell from the rest of your message what other problems you're describing. I did find a troubleshooting page at HP that shows how to address general print quality problems:
Problem with quality of copies
If those links don't solve all of your problems, the Color printing issues page for the 5610 at HP has numerous other solutions:
I know the name of that last link may seem misleading since you haven't described color printing issues, but the links on that page offer different general print problems and their solutions.
Good luck.
Sep 30, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
227 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
