Question about Philips MCD703/37 System
Broken ring that holds cd centered mcd703 - Philips MCD703/37 System
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Why would a year and a half old dell laptop stop charging and give the message "use a 65a Adapter" which is what the laptop came with and I'm using.
Dell uses a 3 pin charger.. inner ring, outer ring, and center pin. The center pin tells the laptop what the rating of the charger is. Is the pin broken? or bent.. or perhaps the charger is bad
Aug 17, 2015 | Dell Inspiron Computers & Internet
How do i replace broken hinge on fuel door for 1999 toyota corolla
Replace fuel filter on 1999 C3500 with 6.5--Loosen the 2 screws that hold the CTIS compressor in place. Move the CTIS compressor forward towards the radiators to give yourself room. The silver cylinder with a black round cap in the center is the fuel filter assembly. Clean up the area surrounding the filter and retaining ring. Unscrew the black cap that encircles the entire assembly. Clean off all the dirt on the retaining ring and filter housing threads. Coat retaining ring threads with grease.-------------------------------------------------------------------------------
lexia3 V47
Apr 10, 2013 | 1999 Toyota Corolla
Double ring burner won't light up.
the outer element may be broken if the center one is the only one getting hot
Apr 07, 2010 | Electrolux 23 in. EHD6670P Electric...
Where should the sub woofer be placed?
The position of a sub woofer is not at all important. Low frequency sound (which is the main output from a sub woofer) is 'non directional' to the ear, so it doesn't make much difference where you locate it.
If it's convenient place it centre back of the room, but I've got mine to one side at the front and it really makes no difference.
Mar 26, 2010 | Philips MCD703/37 System
Durabrand model cd-1493...cd won't play
A friend of mine has one of these, and the same thing happened. Toss in a CD, and the unit reads it, but doesn't play it. Looking at the CD components, all appears to be well, and I was even able to trick the unit into turning on using a paper clip to hold down the "lid closed" switch.
What I found the issue to be was with the lack of downward or clamping pressure the CD was getting with the lid closed. If you notice, with the lid open, there is a round part that "floats" and serves two purposes...one is to align the CD and keep it steady, and the other is to grip it, as the CD's do not snap into the lower centering piece, but rather just sit on it.
I solved the problem by placing a rubber o-ring on it, The one I used is about 1/16" (1mm +/-) and about 1 inch (25mm) diameter. I used some rubber cement to attach it to the top piece. I'm not sure how long this will hold, but it's worth a shot. I figure keeping a CD in the tray will help keep the ring in place as well.
Nov 27, 2009 | Durabrand CD Player with Cassette...
Broken small round piece that holds dvd onto the platter
reset centrel on round piecein dvd player just push carfully and check round piece is sumuthly turned if ok then play DVD /mp3 cd [ if totaly brokon you replace with new]
Apr 06, 2009 | Coby TF-DVD7100 Portable DVD Player
Broken DVD holder/spindle
I have the same issue! if you get a solution please let me know!! I have searched every where with no success.
Feb 27, 2009 | Philips MCD703/37 System
Kenmore 70 series won't spin
If the washer makes a noise from the front bottom center, when not agitating and not spinning, the motor/gearbox coupling has broken.
closed2a0a669.jpg open7976f3d.jpg It is designed to break, if the load gets enough that the motor may be damaged and is simple (enough) to replace
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models but close enough, some have 2 clips some 3
  • remove screws under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips at rear corners
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Oct 26, 2008 | Kenmore 22422 Top Load Washer
Kirby generation III
Hello!
Inside the machine end of the hose is a round rubber ring that holds the hose into the hose end. Take a flathead screwdriver and push the edge of the rubber ring towards the center and downward. MAKE SURE THAT YOU DON'T STAB YOURSELF IN THE PALM WITH THE SCREWDRIVER! lol
It should come out with some hard pushing. Now, just push the edge of the ring inwards again and hold it in place with your other hand. Put it up inside the new hose end and then use the screwdriver to smash the edge back out again to hold it in the new hose end. Hope this helps. If you need any more help, I have a shop on a POPULAR auction site under the exact same ID as I am using here. Feel free to contact me with any Kirby question.
Marci (b0sslady2001)
Oct 15, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Philips MCD703/37 System Logo
20 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
