Question about Homelite ZR10926 16 Chain Saw
How to check chainsaw for problems
Wont run for a long time
    Problem Solver:
  • 7 Answers
Adjust idle, Adjust fuel/air mixture screw, check for clogged fuel filter/line, Take carb apart and clean all ports and screens.
Posted on Nov 21, 2013
Timing chain broke installed new one starts but wont stay running at idle speed
You've asked this question in the 'chainsaws category' Chainsaws don't have timing chains.!
Apr 19, 2016 | Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
My chainsaw wont start
Check to see if it is getting fuel into the cylinder. Does the sparkplug get wet when trying to start?
Jul 18, 2014 | Husqvarna Garden
Saw runs good but when shut off it wont start again for sometime
Check your fuel filter in case it is clogged. When starting pull cord on full choke 5 times quickly. Wait 2 or 3 seconds...try again if it asks like it wants to start..then put on 1/2 choke...goes thru same process. Check spark plug.
Sep 28, 2013 | Stihl 25" Chainsaw Saw Bar 30030008830 Ms...
I have a husqvarna 261 chainsaw. it will start half the time....the other half...no chance.i changed the spark plug.and im getting very good spark. took the carb apart and cleaned it. checked the plug when...
Hi, from what you have written I believe you have a faulty cdi unit. Carbys don't generally run perfectly intermittently. To test the cdi theory, close the sparkplug gap to approximately half normal gap. If the saw runs fine you have a faulty cdi, shorting ht lead or stop wire. Regards Phil.
Apr 26, 2011 | Husqvarna Garden
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Sep 05, 2009 | Garden
Chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Jul 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Stihl 050av Chainsaw run problem
Check the filter inside the fuel tank
Check the fuel line for cracks or holes
Clean the carb
If still not working,replace the pump diaphragm on the carb
Feb 07, 2009 | Husqvarna Garden
Homelite ZR10926 16 Chain Saw Logo
62 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
