Question about Hunter Ceiling Fan Light Switch Control
Where can I find a replacement part G1291-09
It burned out when replacing lights
    Genius:
  • Hunter Master
  • 1,617 Answers
Call 1-888-830-1326
Posted on Apr 21, 2013
How do you repair the surface light on microwave
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when the light bulb in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. Unfortunately, a rather expensive repair for no lights. (Although the circuit board trace can usually be repaired by direct-soldering a wire to replace the burned trace. Sears repairmen won't do this, but an independent electronic technician could do it.
Apr 23, 2014 | Kenmore 62622 Microwave Oven
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
Headlights keep burning out, every other,
There was a recall for this problem...There is a wire harness replacement they will do for you. I had it replaced and still after about 6 months I had to replace a bulb.
Jan 21, 2010 | 2006 Kia Sedona
Burned out light in refrigerator. Replaced with
lube the light base with silcone and tighten . it has a rubber boot to seal it and it sometimes won't let the base of light tighten and touch contacts. **** ..
Jan 10, 2010 | Refrigerators
My 2003 civic Driver side light is dim replaced the power relay but smell burning
CHECK LIGHT PLUG, MANY TIMES THIS GETS BURN, AND STILL LIGHT COMES ON, REPLACE LIGHT PLUG
Oct 28, 2009 | 2003 Honda Civic
2004 Volvo C70 console light
IT IS A LITTLE BULB IN THE GEAR SELECTOR SAME AS ASTRAY LIGHT IT COSTS 10.00 AT A VOLVO DEALER AND THE REASON IT KEEPS BURNING OUT IS THAT BUMPS IN THE ROAD CAN SHOCK IT AND YES IT WILL BURN OUT
Apr 13, 2009 | 2004 Volvo C70
Burned out light in 2000 malibu radio
no, there is no way to replace them as they are LCD lights soldered to the mother board, you will have to replace the radio.
Nov 25, 2008 | 2005 Chevrolet Malibu
Dryers Logo
354 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
