Question about Simer A5500 - Super Ace-In-The-Hole Battery Backup Sump Pump System
Simer A5500 flashing - Simer A5500 - Super Ace-In-The-Hole Battery Backup Sump Pump System
  • 6 more comments
  • Richard Holmes Apr 21, 2013
    This is a Sump Pump battery backup system. Fast beep in sync with flashing "Pump Run Status" and "Charger Mode" (yellow) lights (fast - 2x/second).
    As far as I can tell, this looks like two separate problems (from the manual):
    - Fast beep in conjunction with "Pump Run Status" -- pump is running. No action required.
    and "Charger mode", Fast flashing yellow with no alarm.
    Meaning, System is in the Constant Voltage Charge stage
    Alarm goes because of first issue
    Charging -- This could last up to 14.5 hours. However, the "disable alarm" doesn't work, despite the manual saying that it should. However, the pump appears to be running (first light indicates this). Could be a battery going bad?
    (Sorry for so many comments, but web page wouldn't accept it all at once)
What do i have to do to get back my softwares an drivers for my lenovo a5500-f tablet
Hey there! Because of your particular situation, you may have to perform a hard reset, as it seems the update process didn't complete successfully, leaving your tablet with a corrupt operating system. Before attempting this, please have the tablet charged up all the way so that the reset can complete fully without interruptions.
How to Hard Reset LENOVO A5500 (A8-50) with Hardware Button key:
  1. Press together: POWER + VOLUME UP for about several seconds, then the warning will appear on the LENOVO A5500 (A8-50)
  2. Choose: Reset Device, or Wipe data, or Clear eMMC, until you find an option that works for you
  3. Doing the hard reset will clean all installed applications and all data will be lost or cleared while Resetting LENOVO A5500 (A8-50)
If the information provided does not fix your problem, here's a guide that will help you identify your remaining problem and should help you with solving it:
How to Easily Master Format LENOVO A5500 A8 50 with Safety Hard Reset
Thanks for your question!
Apr 14, 2016 | Lenovo Tablets & eReaders
I have a Simer 2305 and the pump will run but does not when the water is low?
Pumps such as the Simer 2305 do not pump water totally down to ground level. They are designed so they do not suck up debris , sediment, etc, which can clog and ruin the pump. So if your pump leaves an inch or so of water, that is normal.
Mar 15, 2014 | Simer 2305 Geyser II 1-4 HP Submersible...
I can't access web interfaces on switch hp a5500
I suggest try accessing it by connecting it via ethernet cable if you are trying to connect wireless-ly perviously. for information regarding the password and user refer to the manual avaialbe at: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12883&prodSeriesId=4174795
Sep 11, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Alarm won't shut off
This system does not have an alarm. The accessory alarm is something else. Check it's sensor and make sure it didn't get knocked into the pit.
Jun 30, 2012 | Simer A5500 - A5500 - Super...
How do I wire a Simer 2hp pump for 220v?
If it is capable of operating on 220, a diagram should be on the inside of the cover plate or the on the nameplate
May 29, 2010 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
Simer A5500 - Super Ace-In-The-Hole Battery Backup Sump Pump System Logo
131 people viewed this question
Top Simer Computers & Internet Experts
David Payne
David Payne
Are you a Simer Computer and Internet Expert? Answer questions, earn points and help others
