Question about Kenmore Dishwashers
Which of the two wires conecting power cord in dishwasher is the hot wire
Ultra Wash Dishwasher Model No. 665.13042K113 Installing new machine. To add power cord we need to know if black or white wire is the hot wire.
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
  • 34 Answers
SOURCE: I am installing a dishwasher.
If you have a volt/ohm meter you can check for Power on the Blue wire. Or you can open the face of your fuse box and look to make sure the Blue wire is connected to the fuse. If it is, just hook up your Black from dishwasher to the blue from house. White to White ( Neutral). There is no real way to ground the dishwasher if your house wiring is a 2 wire (old) system. You shouldn't have a shock hazard if the wires are in the junction box for the dishwasher.
Bill
Posted on Jun 22, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Posted on Feb 20, 2009
  • 423 Answers
SOURCE: LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Posted on Apr 10, 2009
Krazytech
  • 725 Answers
SOURCE: I am installing a Kenmore
next step to check the door switch...the door must close and the switches on the door must close to send power to the control...let me know
Posted on Sep 19, 2009
It has two grey and one green wire but the instructions tell us black, white, and green
Dishwasher GFCI Requirement ' Electrical Construction ...
ecmweb.com > Forums > Electrical 101 > National Electrical Code (NEC) Mar 4, 2014 - 18 posts - ‎13 authors Sounds like I have to install a GFCI breaker to protect the entire branch ... National Electrical Code (NEC) > Dishwasher GFCI Requirement ...
Dishwasher: Hard Wiring Vs. Plug-In ' Home Guides ' SF Gate
homeguides.sfgate.com > ... > Other Types of Mortgages When you install a pigtail on your dishwasher, you must plug it into a three-prong receptacle. The electrical code does not require the receptacle to be a ground ...
Installing a dishwasher- Does it really need a dedicated ...
forum.mrmoneymustache.com/.../installing-a-dishwasher-does-it-really-n... Mar 12, 2014 - 15 posts - ‎12 authors Installing a dishwasher- Does it really need a dedicated circuit? ... "If your local code requires it on a separate breaker, then put it on a separate ...
electrical - What is code for installing a dishwasher in the ...
diy.stackexchange.com/.../what-is-code-for-installing-a-dishwasher-in-th... Mar 14, 2013 - Current code suggests a dedicated line run to the breaker box for use with the dishwasher. 2008 NEC indicates that the kitchen should have ...
What is the typical dishwasher/disposer electrical connection?
diy.stackexchange.com/.../what-is-the-typical-dishwasher-disposer-electri... Dec 11, 2013 - Checking the wiring for the disposal, might give you some clues as to ... Code that allows Garburators and dishwashers to be cord-and-plug- ...
Dishwasher Connection And Wiring, Oh Boy! - Electrical ...
www.diychatroom.com/.../dishwasher-connection-wiring-oh-boy-10656... Jun 4, 2011 - 15 posts - ‎9 authors Q: should I hard wire the dishwasher or install a receptacle and wire the machine with an appropriate cord and plug? The code says you can do ...
Feb 28, 2016 | Car Audio & Video
We sold our bosch dishwasher, working perfectly. New owners transported it on its back. Now it won't start, or even show that it is getting power, though the outlet works. What has happened?
Hello KT;
My name is Peter. I am a retired field service appliance technician.
Transporting the dishwasher on its back should not have been a problem. It is only with refrigerators and freezers that need to be transported up right, to prevent compressor oil getting into the refrigerant sealed system.
You may have a power cord problem. You have a 3 or 4 wire power cord. If you have a 3 wire power cord you need a 15 amp circuit breaker. If you have a 4 wired power cord you need a 30 amp circuit breaker.
The wall socket that you are plugged into my not have a ground.
You need to check the wall socket and the wire connects at the dishwasher. Send me a model number so I can see what you have. If you have a 4 wire connection you can chance the cord to a 3 wire. On a three wire you have a neutral and two hot with a small green ground wire. On a 4 wire you have a neutral two hot wires and a neutral in the center with a ground wire.
I would put my money on the wall socket not having a ground.
Send me a model number and I will help you.
Feb 07, 2015 | Bosch Dishwashers
My dishwasher did not come with power cord. what kind of cord do it need and how do i connect the cord? On the new cord how will i know which one to connect to the white and black wire? The dishwasher is...
120 Volt 16 gauge, 3 wire power cord.
Brass Screw is Black, White Screw is is Common, Green is Ground....Try Home Deport for a cord. If no screws are on the dishwasher, use wire nuts and elec. tape
Jun 13, 2010 | Whirlpool 24 in. DU930PWP Built-in...
Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
Sep 26, 2009 | LG LDF6920ST Stainless Steel 24 in....
Won't turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
May 29, 2009 | Kenmore Dishwashers
I lost my manual and i can't fiqure out how to connect the dishwasher. i see the light that shows what to wash but the power buttom is not on
When you say connect, I assume you mean you are installing or reinstalling a dishwasher. With the power off, you always connect the black wire with the black wire on the dihswasher. This is the HOT or the LINE wire. The white wire hooks to the white which is the COMMON wire, and the bare copper wire connects to the green screw or green wire and is the GROUND. If you are using a pig tail (plug in connection) the common wire will usually have a line or series of lines going the length of the wire. Just be sure you identify the correct wire because a dishwasher will run with the hot and the common connected backwards which can create a dangerous situation if a short develops inside the dishwasher. Use wire nuts twisted on snugly and enclose all wiring connections in the connection box. Hope this helps! Ken
May 03, 2009 | GE Dishwashers
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
Feb 20, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
My dishwasher
sounds like the fuse on the control blew. you can replace the fuse for around $20 or you can cut and splice the wires for free. If that doesnt work then you may have a loose conection in your junction box under the dishwasher.
Nov 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
