Unlock a key
On my keyboard i have 3 green lights, one telling me the cap lock is on, the second one is about the num lock....what about the third one ( an underlined arrow)? and how can I unlock it
  • SevRoc50 Apr 23, 2009
    What is the third light on keyboard used for?
Scroll lock key. On laptops it is usually controlled by a Fn key. Hold the Fn key while pressing the Scroll lock key and it should go off.
Posted on Mar 12, 2009
How do I unlock my keyboard? On the top right hand corner there is a silver Dell button(that's what it looks like). There are 3 lights with 3 lock emblems, one has the number 9, one has the letter A a
Those "lock" lights are for the NUMLOCK, CAPS LOCK, and SCROLL LOCK features. With each press of the NUM LOCK key, the "9" should cycle on and off. With each press of the CAP LOCK key, The "A" light should cycle on and off, and so on.
Jan 25, 2015 | Dell Computers & Internet
What is the third lock light, I have a Cap Lock, a Numerical Lock. What is the third one?
I beleive it is the scroll light:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F3 Keyboard light down
Fn+F4 Keyboard light up
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Ins Numeric Key Pad on/off
Fn+Num Lk: Scroll Lock on/off
Fn+Del Scroll Lock on/off
Fn+Space Power 4Gear
Fn+C Splendid
Fn+V: Life Frame
Jun 20, 2011 | ASUS 90-A4C1K1000 Keyboard
There 3 lights on the right top side of keyboard - one is capital lock -one is number lock- what is the third one? the light is on and I don't know what to hit ti turn it off.. thanks
The third one is probably Scroll lock. On your keyboard you should see a key labels Scroll Lock or it may be abbreviated. The key may also have the same symbol as the light. You turn Scroll lock on and off the same way as turning Num Lock on and off. Usually involves using the FN key + Scroll Lock.
Mar 12, 2011 | Compaq Keyboard
How to tell if/or when the cap lock and num lock are engaged, I was spoiled when the green lights told you the status. thanks
simply when caps lock key is engaged all you type is always printed in capital letters.in num lock without you can not use numeric keys that are located on right side of your keypad.uyou can always use your numeric keys which are up to ur alphabeticl keys.
if it helped you.plz rate it
Feb 22, 2010 | Microsoft Wireless Desktop 3000 Keyboard
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
How can you know when you are in upper or lower case
I have a feeling there are two ways to tell. First, the receiver unit that connects to your computer should have two LED light on them. One will have an "A". This will be lit when the Caps Lock is on. The second LED has a "1" over it, and that's your Num Lock indicator.
The second way will be after you install Logitech's software, text will appear across bottom of your screen (usually in green) for a second or two telling you if you just pressed the Caps Lock or Num Lock buttons.
Aug 25, 2009 | Logitech Cordless EX 100 Mouse
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Upper right - where green light comes on when you hit "caps lock"
Depending on your keyboard it could be scroll lock, caps lock, or num lock is on. You can turn them off by depressing the appropriate keys on your keyboard until you find the one that turns the light off. Hope this helps.
Dec 22, 2008 | Computers & Internet
Keyboard Light
Num Lock, Caps lock, and Scroll lock indicators in that order. There should be appropriately labeled keys on the keyboard to toggle those on and off as you prefer.
Sep 26, 2017 | Elite Computers & Internet
Computers & Internet Logo
440 people viewed this question
David Payne
David Payne
