Question about Yamata Sewing Machines
Yamata model #03914 manual
I need to time the needle & hook
3 Suggested Answers
  • 1788 Answers
SOURCE: throat plate and teeth broke
Call Yamata at 1-888-292-6282 and explain your problem, they can help you. They are located in Miami, Fl
Good luck
Posted on Oct 06, 2010
Tally Girl
  • 1128 Answers
SOURCE: I have a sewing machine-single needle model 03914,
Use size 60 for very fine (chiffon), size 70 for light weights like voile and cotton, 80 or 90 for medium weights such as a broadcloth, size 100 for denim and size 110 for something very heavy like a thick curtain or upholstery weight fabric. If you aren't sure what size to use, try pushing a needle into the fabric you are going to sew with your fingers, if it goes in easily and the hole it leaves is not noticeable then it is okay, if it leaves a big hole, then go down a size. If you use a needle that is too small on a fabric, then it is going to go blunt quickly or break.
good info here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/Needle-Sizes.--94.htm on needle sizes.
Posted on Apr 08, 2011
A Yamata Industrial model 03914 has not been used for a few years and now when I try the motor cuts off.How do I get it to work?
*Try to blow out the motor with hard, pressurized air to remove dust from the brushes.I don't know if the motor was working or not "a few years" ago.
*Remove the belt off of the pulley to the motor. Try to see if it will run.
*If it runs - Lubricate the pulleys and probably replace the belt. Make sure the belt is aligned with the motor. As the motor is running you will need to align and adjust the stress on the belt. If these are not accomplished the motor will be stressed and will possibly be destroyed.
*If it doesn't run or stay running - Replace the brushes and possibly circuit breaker (if it has one-I'm not sure). Also, look at the cord all the way up and down to see if there are any burn marks. If so then fix the electrical problem.
Feb 02, 2017 | Yamata Sewing Machines
Bobben timing
with needle in centre stitch position remove bobbin cover needle plate and bobbin assy .turn hand wheel towards you until needle at lowest position, watch the rotating hook, as you turn hand wheel slowly to raise the needle 3/16" the hook should be exactly behind the needle and be just above the eye
Feb 09, 2014 | Yamata FY811 Mechanical Sewing Machine
Yamata fy811 sewing machine
The Yamata sewing machines also go under about 6 other names
AEG
YAMATA
HOMEDREAM
FEIYUE
PRIMERA
VICTORIA .
There is a PDF Download of a Universal Manual for these models
It is for many models from a FY700 up to FY812 and more.
The PDF is in English & Chinese and can be downloaded FREE from here
http://www.hennyreimerink.nl/MANUALS/FY700-English_Chinese.PDF
Feb 08, 2013 | Yamata FY811 Mechanical Sewing Machine
SERVICE MANUAL FOR YAMATA FY8700 INDUSTRIAL SEWING MACHINE
my thread deeps bursting, tension is normal. what to do?
Sep 24, 2012 | Yamata Sewing Machines
Feiyue
AEG
YAMATA
HOMEDREAM
FEIYUE
PRIMERA
VICTORIA .
It is for many models from a FY700 up to NM900.
Sep 14, 2012 | Yamata FY812 Mechanical Sewing Machine
Throat plate and teeth broke on yamata model 03914 after one time used,where can I replace this? machine type G C 8500
Good luck
Oct 06, 2010 | Sewing Machines
My manual got lost, need to remove needles, I bought a Empisal Model S4D Overlocker but the manual or CD got lost and I need to get one
look on you tube for overlocker parts instruction.generally the needle is removed by loosenening a little screw which is pushing on the needle from the from.
sewingmanual.com has manuals for sale
Sep 14, 2010 | Yamata FY812 Mechanical Sewing Machine
Sewing Machines Logo
131 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Michael Kovalik III
Michael Kovalik III
Cleverer2
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
