Question about Square D 9013FHG14J52M1X Air Compressor Pressure Switch
Need to adjust on and off steeings
Factory settings to high for my application
  • 285 Answers
Usually you cannot do this... but this is what an air regulator is for. Using the regulator, you can set the desired working air pressure required for your task, despite the ON and OFF settings of the compressor.
Use your regulator (or fit one) to lower working pressure of the air.
Posted on Mar 13, 2009
I have 1999 Polaris Sportsman 500. Just replaced the carb, but now it will not start or run. I've adjusted the idle screw, etc. Ideas?
Adjust idle and mixture screws to default positions - start it and then make the necessary adjustments. Idle speed, low and high speed mixture settings if applicable..
Aug 28, 2017 | ATVs
I just replace the iner e outer tie rods and just had it balance e still the front steeing shakes and sw s ys a little please help i have a 2007 nissan quest whit 95000miles thanks ...
have a wheel alignment done after checking out the front suspension. You may have what is called castor wobble for negative castor settings. Check wheel bearings for condition and adjustment.
Jul 27, 2014 | Cars & Trucks
Need craftsman chainsaw manual
2 cycle engines almost all share the same characteristics when setting the carb. this link should get ya going. remember if the piston is damaged you wont pump fuel. carb adjustment screws dont adjust themselves. google(piston blow by) http://www.tillotson.ie/docs/techinfo_HS_US.pdf
Feb 07, 2014 | Craftsman Garden
What is the factory setting for lowand high screws on 25cc craftsman blower
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Nov 20, 2013 | Garden
What's the oil/gas mix ratio on a Mac130.. and also what are the factory/normal settings on the high/low carb adjustments screws.
Run it at 25-1 with a good two stroke oil, base settings are 1 turn on the high and 1 1/4 on the low, you will need to fine tune from there.
Jun 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do i adjust bandwidth on E3000
There are several possible answers to your question, depending on what you're referring to as bandwidth.
On the Linksys E3000 router, you can increase your total bandwidth by utilizing both the 2.4 GHz and 5 GHz bands for your wireless N networks, and split your wireless connections between the two. This can be done with the Wi-Fi Protected Setup option, or manually through Wireless > Basic Wireless Settings. Note that each network should have it's own SSID and password.
You can adjust the bandwidth priority of certain applications and devices. You can set priorities from High, Medium, Normal, or Low, to control your network traffic. Setting a program to have high priority lets it use more bandwidth; setting a low priority keeps the program from using too much. To adjust these priorities, go to Applications & Gaming > QoS.
You can adjust the maximum outgoing bandwidth that your applications use as well. By default, the router will decide how much to allow your applications (Auto setting). You can change this to your liking by selecting Manual and specifying an amount in either Kbps or Mbps. This is also on the Applications & Gaming > QoS page.
Jun 09, 2011 | Computers & Internet
Need to restore my 372xp chainsaw carb to factory settings. It had emission limiters fitted that have been removed.
The factory settings on both my 372's are 1 full turn on both high and low adjusters.
Sep 16, 2009 | Husqvarna Garden
The steeing column in my 95 Olds Cutlass
does the key have a computer chip built into it. i think it does . if this is the case that,s your problem. the key has to match the computer in the car it,s programed from the factory like this. you either have to use the original ignition lock and key or get the lock in your new column keyed to your original key by a lock smith. than your car will start. good luck.
Apr 18, 2009 | 1995 Oldsmobile Cutlass Supreme
How to adjust the high/low on pouland P3416, need a special tool?
it can only be adjusted by a certified tech and has to be taken apart and set to factory specs.
Mar 05, 2009 | Garden
Square D 9013FHG14J52M1X Air Compressor Pressure Switch Logo
401 people viewed this question
Top Square Air Tools & Compressors Experts
John Trevino
Bill Boyd
Are you a Square Air Tool and Compressor Expert? Answer questions, earn points and help others
