Question about Genie Company Genie 27884W 4 Wire Wall Console
Why did 27884w quit working - Genie Company Genie 27884W 4 Wire Wall Console
My 2003 gmc Sierra driver side door panel quit working, locks quit, seat heater quit, windows quit, passenger side works fine
The most likely culprit is your driver's door control module... it's built into the driver's window switches. Double-check all your fuses before replacing any parts.
Jan 27, 2013 | 2003 GMC Sierra 1500
Speedometer & odometer both quit after working intermittantly over time. For some time the odometer worked when the speedometer would only work once in awhile.They finally both quit together. There is...
if one or the other quit working and then both quit working then i would have to say by looking at the electrical diagram that it would be the speedo head itself. it sends only one signal to speedo head that the vehicle is moving so if one was working and not the other then the sensor in the trans should be doing its job but if both had quit at the same time i would say sensor in trans. good luck hpe this will help you let me know...................
Jun 18, 2011 | 1994 Toyota Pickup
My speedometer and odometer quit working. I replaced the sensor on the transmision and it didn't fix the problem. By the way, the part cost me $174.00 + tax. That was an employee price sence I used to be a...
The odometer quits working when the speedometer quits working. The most common cause for the speedometer to quit working is the speed sensor in the transmission. You said you replaced it, there is also a transmission speed sensor on your truck that may need to be replaced. I understand your frustration, but there is nothing else that would cause the speedometer to quit except the cable behind the gauges being clogged.
Sep 07, 2010 | 1993 Toyota Pickup
Ac/heater blower quit working power windows quit working wipers quit working radio quit working all at the same time 2004 grand caravan
check main power panel under the hood for aux fuse, should be in the 40 to 60 amp range possibly slightly larger than standard fuses.
Nov 26, 2009 | 1999 Dodge Caravan
Heater quit working (would only
Sounds like your auto climate control module.
Aug 11, 2008 | Mercedes-Benz E-Class Cars & Trucks
Genie Company Genie 27884W 4 Wire Wall Console Logo
51 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
