Question about HP Black Pavilion p6-2143w Desktop PC with AMD Quad-Core A6-3650
How to add a hard drive to HP P6-2143W - HP Black Pavilion p6-2143w Desktop PC with AMD Quad-Core A6-3650
How do I add a hard drive?
Shutdown the Pc. open the door that leads to the hard drive.
Assuming there is enough room inside: if you want to add an IDE drive look at the want you already have and find out if the jumper is on "master" or "cable select:. If it is master then you want the new drive to be a slave. If cable select then the new one also on cable select.
If the drive is SATA just find a power cable an a sata cable and just attach the cable. The only go one way look at the connectors. No jumpers.
Jul 13, 2014 | HP PAVILION A6230N DESKTOP PC
Replace cooling fan now hp test said hard drive bad
no you can get a hard drive cooler fan for harddrive.
Dec 01, 2013 | HP Computers & Internet
How do i find my hp compact ,the model # to look for the manuel for my comp, i have a hard drive i guess it's a new type and i want to add another hard drive but it's the old conection, what i can do ,,
I assume you new hard drive is a SATA hard drive and your HP only has an IDE hard drive.
To install a SATA hard drive in the HP, you will need to install a SATA controller card in your HP so the SATA hard drive can work in the HP computer. You will also need a power adapter lead for the SATA hard that converts the 4 pin power connector to a SATA power connector.
Mar 10, 2011 | Compaq Computers & Internet
Is there instructions on how to add a second sata internal drive to my new desk top pc.
yes there is pls. go to this link as it will give you the instructions on how to add additional SATA Hard drives.
http://www.wikihow.com/Add-an-Extra-Hard-Drive
Mar 06, 2011 | HP Computers & Internet
I WANT TO ADD A SECOND HARD DRIVE WHAT WOULD BE THE PART NUMBER FOR THE CADDY.. AND ALSO UP TO WHAT SIZE HARD DRIVE CAN I ADD
The only practical way to add a second hard drive to the dv9720us is to use an external USB unit. There is no provision for a second internal hard drive (standard for laptops). The "expansion port" is simply another wire connection to the motherboard's data bus, and requires a proprietary cable from HP. Using a USB external drive is a standard approach and does not require any special drivers, etc.
There are a number of good external hard drives w/USB connection available from Costco, WalMart, KMart, and other retailers. HP prefers Western Digital (as do I, from years of repair experience...they last longer), but there are a number of decent brands. You can use any size you want. 1TB drives are not uncommon today. Prices generally range from a little under $100 to around $200 for large capacity drives.
Hope that's helpful.
Jan 01, 2011 | HP Pavilion dv9720us Notebook
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
RE: HP Compaq D530S desktop PC
there is no extra room the only way is upgrade the hard drive whid a biger one man and the hard drive is eide interface if you atenp to bye one thanks
Oct 17, 2009 | HP Compaq d530S PC Desktop
HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Mar 29, 2009 | HP Media Center m7250n (ED842AA) PC...
Finding it difficult to install a second hard drive on hp dc7700
some older sytems don't have the option to add a second hard drive
can you save your files on cd's or travel drive and then install the new hard drive
Jan 16, 2009 | HP RT810UTABA - HP dc7700 small form...
HP Black Pavilion p6-2143w Desktop PC with AMD Quad-Core A6-3650 Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
