Question about Kenwood eXcelon KDC-X969 CD Player
Kenwood x969 not working
All fuses are good. gets power on both remote and steady. good ground. with the face off i see the security light flash. all seems to work at first, the face starts to flip but it will just go to a flat horizontal position for a second and then close. kenwood x969 has one of those stealth faces so i cant see if theres any kind of error codes it just closes and does nothing after that. it was working fine had it for a year or two. this just started one morning and has been a problem since. went back to my stock radio, works fine. the problem is somewhere in the kenwood. can it be the face? something with the contacts? or just completely blown?? anyone know how i can trouble shoot this problem to see what the problem is? or have any ideas? ive been installing systems for 5 years now, unprofessionally, but i know plenty as far as installation goes. normal problems i can fix. this one not so much
  • Anonymous Mar 27, 2014
    Power Amp, w/ subwoofer, and Eq. don't turn on unless system its on.
    Power amp, EQ, Subwoofer, don't turn on.
    Problem Solver:
  • 11 Answers
Hi,this unit sounds like one with a motorised face. the problem could be with the flat ribbon cable connection between face and main pc board. chech for cracks alond the body of the ribbon especially where it bends alot. Also try resetting the unit if the unit has a reset switch or reset function.
Posted on Aug 04, 2007
SOURCE:
Kdc 448u has power but will not work
If you are sure that the unit has power, try resetting the unit. The reset button is on the left of the plug behind the faceplate.
Aug 19, 2012 | Kenwood Kdc448u
Kdc-x969, when the unit is tured on the face does not flip down. most buttons turn the unit off but the face flips down instead of up when it shuts off
It very well could be that the internal motor that moves the faceplate is going out or has already gone out. It sounds to me like that could be the problem.
Apr 12, 2011 | Kenwood eXcelon KDC-X969 CD Player
My amp does not work
Did you check to see if its grounded well? Try grounding the amp to the battery, also check fuses. I'm not sure how you hooked it up, but I usually connect the amps directly to the battery with a heavy duty fuse. Also try the remote wire, from your cd player to the amp. Thar are usually 2 different remote wires make shure thair hooked up right, if thats all good and the amp power light isnt on then it sounds like your amp is bad.....
Dec 11, 2009 | Kenwood Car Audio & Video
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
My amp for my car has a steady blinking power light for about a minute then immediately blows the fuse?
This one should be quite easy to troubleshoot. Start by disconnection every wire on the amp, including the RCA's. Connect the ground, then the 12v power. The light should still be off. Use a jumper from the main 12v in to the remote in. The light should come on. If it doesn't after doing exactly this, or if you still have the same problem- internal amp [email protected]
Sep 10, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
Kenwood KDC -X969 Won't power up
Try pressing the reset button when it slides halfway open. It's a little hidden on the main button panel at the bottom. You'll need a pencil or something to press it. This usually happens to me when it's too cold and I have the panel angle set to full down tilt on my 879.
Mar 16, 2008 | Car Audio & Video
No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Jul 20, 2007 | Kenwood KDC-2019V CD Player
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Kenwood eXcelon KDC-X969 CD Player Logo
219 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
