Question about Rode M3 Professional Microphone
Rode m3 bad ground
Bmw m3 1995 clicking noise when i turn on my motor does that mean the engine is bad?
What kind of clicking?
If it's a rapid, multiple clicking (like a machine gun), it's USUALLY a low battery, or a bad connection.
A single click for each turn of the key to the START position is USUALLY a bad starter relay or solenoid.
Apr 28, 2014 | 1995 BMW M3
I rode my motorcycl into work and it was fine. When i went to leave nothing no lights, no power its not the battery and i change the ignition still nothing. what should i check next
Check you battery cables. Make sure there is no bad ground or any corrosion. If you have a bad ground to the battery, engine or frame this can cause electrical problems. If that is not the problem then check the main fuse to see if it is blown.
Feb 19, 2011 | Suzuki GV 1400 Cavalcade LX Motorcycles
I have a broken wire on a rode m3 microphone and wonder how to open the mic to repair.
if you don't know how to open your microphone, I recommend not doing so.
Feb 06, 2011 | Rode M3 Professional Microphone
Hi The grill cover came off my Rode M3 and the wires have come loose. Its very hard to get in and solder! How do I take it apart to do so? Thanks! Nick
If you have good manual dexterity, a head for detail memory, and good soldering skills on SMALL wires, you may try reconnecting them. The grill may need to be reshaped and then held in the original position with contact cement. Test the mic before you attempt the last part. Otherwise, you may want to let a pro do this. As always, you have to weigh the costs against your own abilities to do this, keeping in mind the value of the mic. I can tell you that, as an experienced tech in this area, I only attempt this delicate work when I feel 100% and undistracted.
Oct 06, 2010 | Rode M3 Professional Microphone
BMW M3 E46 Stereo whine
What you are hearing is ground loop interference. If you have an aftermarket headunit/amplifier this is a common occurrence. A ground loop isolator in line with the low level amplifier inputs should solve the problem. Otherwise, it may be a malfunction of the stock cd unit or amplifier. BMW used a balanced input on some of the stock amplifiers, which would make ground loop interference all but impossible.
Apr 18, 2009 | 2002 BMW M3
Bad image when start toshiba tecra m3, don't start
OK, now it's definitely either bad GPU or bad VRAM or both.
Needs to be repaired (BGA reflow) or replaced.
Mar 18, 2009 | Computers & Internet
CASSETTE RECIEVER...(KENWOOD)KRC-585/M3
can you please find a cod for keenmood krc-585/m3
thank you
Sep 26, 2007 | Kenwood KRC-38MR Cassette Player
Rode M3 Professional Microphone Logo
32 people viewed this question
Top Rode Audio Players & Recorders Experts
Jay Plesset
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
