Please DRIVE usb adapter Airvast model:WN220
DRIVE
  • Anonymous Mar 13, 2009
    "please DRIVE usb Wireless adapter Airvast model:WN220"
  • 611 Answers
Www.download.com/VIA-USB-2-0-Host-Controller-Driver/3000-2098_4-10163319.html - 80k -
www.softwarepatch.com/tips/usb2-driver.html - 11k
go for this website and download it
Posted on Mar 12, 2009
Please help me with this
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Nov 03, 2012 | Computers & Internet
What connector does this hard drive have? Sata or ata? Or what is called? http://www.flickr.com/photos/78399316@N03/7183923756 I need an USB adapter to recover the data from this hard drive, that's...
You have not specified the make and model of the hard drive so it is impossible to give you the correct advice.
I suggest you take your hard drive to the computer shop and ask them for an USB adapter that connects to your hard drive. That way you be certain to have the correct USB hard drive adapter.
May 12, 2012 | Fujitsu Computers & Internet
No computers will recognize my externaml Hard drive. Its model number is usb160. whenever i plug it in to anything, all it shows is a flashing blue light. Can you please help?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 26, 2010 | Verbatim 160GB USB FireLite: The "drive...
I have a old TOSHIBA 80GB external hard drive , i dont have the model number the problem is whenever i try to access the hard drive it shows that the hard drive is enabled but on my computer it appears...
* the USB cable
* the power-adapter
Nov 18, 2010 | Toshiba Computers & Internet
How do i download my wireless usb adapter when my notebook doesn't have a disk drive
You should have an adapter built in and shouldn't have to use a usb adapter. Please post what model u have and tell me if u have a picture of a little sattalite on the right side of ur computer.
Apr 03, 2010 | Acer Aspire One PC Notebook
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Trying to find a replacement mini pci wireless card
That jack is 4-pins of USB and 2-pins for 3.3 volts .  The card is somewhat proprietary. EBay WM168b  it was manufactured by Airvast Tech
Dec 28, 2008 | Averatec Computers & Internet
Network adapter
download a program called driver genius (its free) this will scan youre pc and inform you of all the drivers you have or require.if you purchase the program it will find and install them for you.but it solve youre problem.if next time you could mention brand of laptop I could probably tell you the drivers you need or at least the site.
Oct 08, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
Computers & Internet Logo
1,039 people viewed this question
David Payne
David Payne
