Question about Vector 995 Radar Detector
Vector 955 displays voltage instead of mode - Vector 995 Radar Detector
2 Suggested Answers
SOURCE: my beltronics vector 955 radar detector displays a
I have the same problem. did you find a fix?
Posted on Jan 10, 2011
How to solve a 3 x 4 system after plugging in the values
I am not sure what you mean by a 3X4 system. I know system of n equations in n unknowns. It is written in the form of an nXn matrix A multiplied on the right by an n vector (X), and n vector B holding the right hand sides (constant values)
[A]*[X]=[B]
In the EQUA mode, the calculator offers you a template to enter the numerical coefficients in the horizontal sequence a11, a12, ... a1n, B1
Fill the first line, then the second line, etc.
Once you finish entering the coefficients and the constant terms press F1 (SOLV) to launch the search for the solution. The result is displayed as a vector. (vertical vector).
Oct 29, 2013 | Casio FX-9750GPlus Calculator
Take apart 955 beltronics
There are 2 screws you need to remove. The first one is in the corner of the base (flip it over and you will see it). The second screw is under the Beltronics sticker on the base, right below the first hyphen in their USA phone number. If you rub your fingernail around that location, you should feel the depression. I didn't remove the sticker, I just stuck my screwdriver over the sticker and unscrewed it through the sticker. Hope this helps.
Mar 28, 2012 | Vector 995 Radar Detector
I bought it at a pawn shop, whenturned on, it says calibrate. How do i do that?
Hold down the "Brt" and "City" buttons as you power the unit on. This will reset the unit to it's default settings. It worked to restore mine to operation.
Dec 01, 2010 | Vector 955 Radar Detector
My Suunto Vector Watch was in storage for a year or so and had no display when I went to use it. I relpaced the battery with a new one (checked it with a voltmeter to ensure it was good) and still no...
mcdevito75 here, Double check the battery install, make sure all contacts are clean, with the watch open see all buttons depress and are hitting points on the movement. When done, presss the mode button and display should come up.
Aug 09, 2010 | Suunto Vector Wrist Watch
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
Service required
This message is generated only after a Bel or Escort radar detector has repeatedly encountered problems while trying to self-calibrate its radar detection circuitry. The Service Required message literally means that you must send in your RD for service since there is nothing that can be done to fix whatever the problem is short of sending it in for factory service. At least it will come back working like brand new!
Mar 06, 2009 | Vector 955 Radar Detector
V955 does not work
Turn the unit off and then, while holding down the City and Brt buttons, turn it back on. This restores the factory default settings. Worked for mine with the exact same problem. Be sure to use the power switch though. If you just unplug the cord and plug it back in, it won't work.
Jul 27, 2008 | Vector 955 Radar Detector
Faulty Buttons
Return to Beltronics for repair. 1-800-341-2288.
Jun 14, 2008 | Vector 955 Radar Detector
Vector 995 Radar Detector Logo
61 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
