Question about Hotpoint Washing Machines
Hotpoint WT541 extra rinse and on/off light stays on. Machine doesn't start
Had a blockage in the front filter. have removed that . But still not starting. The Extra rinse light and the on/off light stays on. Have blown into the pressure switch, can hear it clicking .
  • 47 Answers
SOURCE: I think there is a blockage in the machine,but
I have seen socks get stuck in the pump, They are usually clear plastic so you can look into them. look for the discharge hose attached to the pump to aid it.
Posted on Jun 25, 2009
SOURCE: hotpoint washer
hotpoint wma22 will not spin
Posted on Jan 01, 2010
  • 6277 Answers
SOURCE: hotpoint wml 540g the fault is the machine starts
In a word 'yes'!
Either the interlock requires adjustment if that is physically possible on your machine or the sensor requires checking and possibly replaced.
For me this is a rare quick answer- I normally rant on............................... :-0)
John C
Posted on Feb 28, 2011
ercupa190
  • 12223 Answers
SOURCE: hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Posted on Oct 12, 2012
richroth
  • 9472 Answers
SOURCE: Why does the washer set on normal go into the extra rinse but doesn't spin dry? (Extra rinse switch not on)
You will need to replace the timer. Here is the part to order.
Posted on Dec 03, 2012
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Washing machine not rinsing and spinning wf440
I would suggest that you check and clean the pump filter.
This is to be found by removing the lower panel of washer, then remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint WF430 Front Load Washer
While on a cotton wash machine continues until the rinse cycle stops and shows f5 machine blocked.
You need to clean the filter.
Remove lower rear panel of washer/
Locate and remove large black hose on bottom of drum.
Rempve hose onto pump, and check for blockage and or obstruction here as well.
This should solve the problem.
Please leave feed back for my solution.
Thankyou.
Jan 11, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
It sounds like you still have a blockage either in the outlet hose itself or in he pump. If you know how to remove the outlet hose from the bottom of the machine but be aware a lot of water also might empty from the machine when you do this. If you use an object such as a pen and put it in the outlet hose no blockage it wll come out. Then gently feel around the pump opening for any objects. Finally gently spin the pump propellor to make sure it turns smoothly. Replace hose and test. Hope this helps.
Jan 19, 2009 | Hotpoint Washing Machines
Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Dec 29, 2008 | Hotpoint Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
