Question about Sanyo DS24205 24" TV
Apex 51 inch projection model gb5108
T.v works fine for a while then goes to thin rainbow across middle of screen. If you turn it off for a while it will come on and work fine again for a while. It has a thin bar of color all the way across the middle of the screen. Please help what could be wrong?
  • 1 more comment
  • scott andrews Aug 03, 2007
    now the tv is working fine but there is a faint
    red line across the middle of the screen going
    horizantally. Is this in the screen or in the signal?
  • scott andrews Aug 16, 2007
    thank you for trying to help me.Im pretty sure
    something in a board is starting to short out or burn up. the problem is I cant parts for this t.v.
    If the problem was identified could it be resoldered. Should I just buy a new tv
    this one is a little over a year old
  • Anonymous Jan 08, 2008
    a rainbow line goes across middle of screen
The signals on each projector are the same and swappable. you can use a signal cable or plug off of another gun like green to trouble shoot with to see if the red signal is the problem. also press on any chips or plugs to make sure they are seated good on the board inside TV. Also on the pc board inside diods and regulators break down with heat when they are going bad.
Posted on Aug 15, 2007
I have worked on projection displays for about 17 years 20years electronic. and this sounds like a vertical deflection amplifier problem. this is if the lines or the rainbow you said that you see are horizantal.
Picture reduces to about 2 in across middle of screen
Probably theelectrolytic caps around the vertical are failing or there are some bad solder joints in that are. See if tapping around the area restores the pic, if so resolder until it is better.
Apr 14, 2008 | Apex Digital GB5108 51" Rear Projection...
Convergence IC's
Lines going across is a little vague but there is always the problem with the electrolytics (caps) around the vertical, be sure and get the one on the power supply too. Just change all you can find(usually 4-5). Thre are 2 convergence ic's if you didn't change them both, resolder the other one.
Then check the value on R519 for me.
Apr 09, 2008 | Apex Digital GB5108 51" Rear Projection...
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Three colored lines across the middle...
Sounds like the vertical control IC has gone out. Replace IC N301 (TDA8351) and check or replace R370 (1ohm), R371(33ohm), and R380(1ohm). This shouldn't affect the sound but once you get video you might figure out what is wrong with the sound (control setting). The TDA8351 crosses to NTE7156 and shouldn't run you more than $10.
May 28, 2007 | Apex Digital GB5108 51" Rear Projection...
SOUND NO PICTURE ONLY RAINBOW
I just fixed this problem on my neighbor TV. I don't have a manual or schematic, and didn't pay any attention to the reference designators, so I will just have to describe it. The problem was a bad solder joint. Visible thermal fatigue. Looking at the main board, (didn't even need to slide the cassis out). There is a small, narrow, vertical board in the center, adjacent to the yoke connectors with a funny looking little transformer on the very top. Check the connections on that.
-John
Dec 15, 2006 | Apex Digital GB5108 51" Rear Projection...
APEX TV problems
need flyback transformer #030531-5283
Nov 05, 2006 | Apex Digital GB5108 51" Rear Projection...
Sanyo DS24205 24" TV Logo
99 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
