Question about Konica Minolta Office Equipment & Supplies
F 26 error code on konica 2223 - Konica Minolta Office Equipment & Supplies
5 Suggested Answers
  • 87 Answers
SOURCE: I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Posted on Dec 16, 2008
firecontrol7
  • 6680 Answers
SOURCE: error code P27
Description
P26 or P27 at power up or during copier operation.
Solution
PROBABLE CAUSES:
1. Open connection from the TDS sensor to the main CB or lack of developer. The TDS output is abnormal (0.2V DC or lower).
Verify that the sensor output is above 0.2V DC by monitoring CN6-A9 on the main CB while running the main motor in diagnostics (47 mode, output code 40).
Repair any poor connections to the TDS sensor and supply developer if necessary.
2. Code occurs after resetting the PM counter and P26 occurs if machine is powered OFF/ON, because the L-detect (TDS) adjustment was not performed
Posted on Jul 31, 2009
  • 51 Answers
SOURCE: f35 error code
Warm-up was not completed
within a specified period from
the start of warm-up.
• The low fixing temperature
fault detection software is
activated.
The fixing temperature at the
end of warm-up is less than the
specified temperature.
activated.
The fixing lamp does not turn
OFF within the specified period.
SOLUTION
Rewrite the data at
address “P47” in the
25 mode to “0”.
(1) Turn the main switch OFF.
(2) While pressing the numerical keys 2 and 5 of the copy
quantity setting button, turn the main switch ON. This
will enable the 25 Mode. The 25 Mode is used exclusively
to rewrite in memory and, therefore, does not
support normal copy operations.
Posted on Aug 31, 2009
  • 3 Answers
SOURCE: frequent paper jams with my Konica 2223 photocopier
I believe u have cleaned all the optics right? if yes then,check if ur dev. is over toned run a few copies with flat top cover open
if not then change the dev and see if it works
Posted on Nov 07, 2009
Toner Level Sensor konica 2223
what about the toner level sensor for the Konica 2223????
Jun 25, 2014 | Konica Minolta Minolta 2223 Laser Printer...
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
HOW TO RECTIFY THE error code F-88 in konica 2223 copier
check your wiring on your board and maybe its a lost contact, or try to replace a new board
Mar 16, 2010 | Office Equipment & Supplies
Affter adding developer to my konica 2223, How do I reset the machine. (to clear ''routine service req'' on the display.
turn the machine off hold down 4 and 7 key turn on enter 9 0 then the date power off then on while holding 47 again and press 5 1 and start if you dont run the 5 1 you will get an error code and not be able to use the machine
Sep 29, 2009 | Konica Minolta Office Equipment & Supplies
How do i set up a konica 2223 copier to print using it as a network printer
the 2223 does not have that feature if you want a copier that is comparable to the same speed and features you would have to buy the konica minolta bizhub 222 new model or there are a lot of low mileage used bizhub 200 machines coming off lease for sale
Sep 28, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
Description
Solution
PROBABLE CAUSES:
Jun 01, 2009 | Konica Minolta Office Equipment & Supplies
Dec 16, 2008 | Office Equipment & Supplies
Konica 1212 again!
Try "47" 51 it is possable to try the set up run again before but wait until the machine finishes its cycle if you still get F26
replace the deveolper.
Thank you
Feb 20, 2008 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
Copier konica 2223
The problem is your toner density sensor, either your sensor is bad, someone reset p.m. count without running density reset mode. turn machine off hold down 4 then 7 while turning machine on, select 5 then 1 press start print.
Dec 21, 2007 | Office Equipment & Supplies
87 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
