Question about WeightWatchers Body Fat Monitor No.WW70M
How do I set a taylor body fat scale model 5776f
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    How do you calibrate, it's a body fat scale, can't find model #?
    It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
    If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
    Taylor USA FAQs Scales
    Searches related to Taylor body fat scale model number location
    taylor body fat scale model 5741 manual
    taylor body fat scale model 5761bf
    taylor body fat scale model 5731f reviews
    taylor body fat scale accuracy
    taylor body fat scale 5731 review
    taylor body fat scale athlete mode
    taylor body fat scale readings
    taylor body fat scale5758f manual
    Aug 01, 2014 | Taylor Health & Beauty
    I need a Taylor 5579 Body Composition Scale Manual
    Check under your scale, mine had the instructions listed there
    Feb 10, 2013 | Taylor 5568 Fat Scale Stainless Steel ()
    Where do I get a manual ?
    you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
    Apr 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
    I need an instruction manual for my taylor body fat scale #5568.
    I posted the manual in my photobucket album here:
    http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
    Amy
    Nov 01, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
    How do I get A manual for model 5599 scale?
    Taylor customer service would be able to send you a copy of the manual either by mail or email. Here is their number. 1-866-834-3905. Here is their website. http://www.taylorusa.com/taylor-support
    I hope that helps :)
    May 14, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
    How do i program the taylor body fat scale
    From the Taylor web site
    http://www.taylorusa.com/faq-scales
    The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
    In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
    The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
    Jan 15, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
    How do I get the detailed instruction manuel for the Taylor Bodyf
    This link allows you to trouble shoot and download manuas directly with/from the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
    Dec 01, 2008 | Taylor 5593 Body Fat/Body Water Scale
    WeightWatchers Body Fat Monitor No.WW70M Logo
    115 people viewed this question
    Top WeightWatchers Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a WeightWatchers Health and Beauty Expert? Answer questions, earn points and help others
