Question about Shelti Cougar Eye 2 Electronic Dartboard
Shelti eye 2 dart board
Reset programing code
Hieght of bulls eye from floor
Fred, First, we need to know what type of bullseye you are talking about??
If you are talking about a target.. seems as though you can put it anywhere you chose..If you are wanting to throw darts...in competition..
The official height of a dartboard from floor to bulls eye is 5 ft. 8 inches (1.73 m)
How High to Hang Dart Board From Floor to the Bullseye
Jul 09, 2017 | Office Equipment & Supplies
Dartboard height and distance
Gary, Standard height from the floor to the bulls eye on the dartboard is 68" inches (173 cm) and the distance from the front face of the board to the toe line should measure 93 1/4" (237cm).
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.pdc.tv/rules-of-darts
Darts Dartboards and Dart Supplies Dart Brokers
Dartboard setup
Apr 20, 2016 | Toys
Height and distance of a dartboard
Discount Darts Dartboards and Accessories
Plastic tip: The toe line measures 8' from the FACE of the dart board, (not the front edges)
Steel tip: the toe line measures 7' 9 & 1/4'' to the FACE of the dart board. ( not the front edges)
Under both circumstances the center of the bulls eye is 5'8'' from the floor.
Sep 07, 2014 | Sport & Outdoor - Others
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Jul 24, 2014 | Samsung SGH-T499
Need owners manual for Echowell dartboard
Dart board is target for game of darts and is quite similar to round bull's eye target in archery. It comes with sharp darts having steel tips and are constructed mostly from wood, 39.4 cms or 15.5 inches big. Players spend a lot of time in perfecting their throws on this section of dart board. http://www.whatisall.com/games-and-sports/what-is-a-dart-board.html
Mar 29, 2013 | Sport & Outdoor - Others
How to choose the right dart tip?
Steel tip darts are mostly used with bristledartboards. Steel tip darts have a very sharp steel point to stick in the fiberof a bristle board. Soft tip darts are mostly used with electronic dart boards.Soft tip darts have a flexible, plastic tip on the end to easily lodge into theholes on electronic dartboards. I prefer the soft tip because it's usuallylighter than steel tip darts.
Aug 01, 2012 | Sport & Outdoor - Others
How high should I hang my dartboard?
In a standard game, the board is hung 172 cm from the groundmeasured from the center of the dartboard (bull's-eye). Another way to hang theboard is to measure 172 cm from the ground and measure 293 cm diagonally fromthe bull's-eye.
What are the general rules of playing darts?
The rules of darts are quite basic. I will outline them for you here:
  • - Each player turn consists of throwing 3 darts
  • - Both feet must remain behind the throw line until the dart has been thrown
  • - Darts that bounce off the board (by hitting the wires) do not score and cannot be re-thrown
  • - If a dart falls out of the board during your turn, the darts are disqualified and the points do not count
  • - Darts dropped accidentally can be picked up and still played
  • - After 3 throws, the player must remove their darts from the board
Jul 26, 2012 | Sport & Outdoor - Others
How do I hang the dart board?
When hanging a dartboard, you may try to follow theaccepted rules. The Throwing distance should be 7'91/4" (2.37m) and youshould measure a distance of "68 (1.73 m) from the center of the bulls eye tothe floor.
Jul 09, 2012 | Sport & Outdoor - Others
Am stuck in garden shed on mcf millionheir i cant
when looking for the bulls eye. Find the dart board, press the L or R button and turn ur pen in a circle on it. When u are looking for the king me. Look at the file cabinet under the dart board. The King is upside down on the side of it.
Jan 15, 2010 | Nintendo Mystery Case Files: MillionHeir...
Shelti Cougar Eye 2 Electronic Dartboard Logo
134 people viewed this question
Top Shelti Sport & Outdoor - Others Experts
Bill Eager
Are you a Shelti Sport and Outdoor - Other Expert? Answer questions, earn points and help others
