Question about Garden
LawnBoy 10642 starter rope replace
Lawn Boy 10642
3 Suggested Answers
  • 3600 Answers
SOURCE: lawn boy mower bought used wouldnt start then the rope broke
there are 3 bolts that you remove and thatwill allow the coil houseing to come off pull off buy new rope and wind the rop onto the rope holder then roll the spring to it's tighest postion put pull handle on and tie know it rope burn the end of the rope with a lighter to keep it from comming apart, be sure to thread the rope threw any holes before tieing knot. then replace it back on and bolt it together. and your set.
Posted on Jun 22, 2009
hallett18
  • 11 Answers
SOURCE: lawn mover starter rope replacement
most starters can be taken off the engine and replace the rope without completely tearing the whole unit apart. by that I mean you should not have to mess with the recoil spring unless it is broken. remove old rope from pulley, wind up the pulley and hold it so it wont unwind, replace new rope onto pulley and tie a good knot and melt the ends of the rope so it wont unravel, then slowly let the pulley retract the correct amount of rope. if the recoil spring has unsprung on you, it will take a little time and probably several tries to wind it back up and position it back in the starter. they like to unspring while doing this so take some time and an extra person to hold and assist might go a long ways. good luck. R
Posted on Aug 25, 2012
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
Rj19lm plug gap for a 195cc 4cyl lawnboy
As a starting point in my shop i always use 0.30 in. For all my mowers
Oct 11, 2014 | Lawn-Boy lawnboy" Mower Blade 21"
Wrong part received?
it probably is lawnboy are good for sending the wrong parts dont buy lawn boy or tecumseh engines both junk
Aug 13, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
I need an engine diagram to help me put my lawnboy 10642 briggs and stratton eng ine back together
Go to partstree.com and search your model number and you will see an exploded view. Thank you for using fixya.
Aug 22, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
Pull cord gets stuck
I recently had a similar problem with an old briggs 3hp engine. In my case the starter clutch was not engaging properly. I then removed the starter rope/clutch mechanism, cleaned it, and rewound the spring. This job is not too difficult but requires a little research if you haven't done it before. It was my first time so I watched several youtube videos (separate videos for the clutch and the starter rope). A few important details on winding the spring were described in the user manual for the Briggs starter rope replacement kit (about $10, including the winding tool). Good luck!
Aug 03, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
I have a Lawn Boy mower, model 0642, and the cord will not recoil. (There is a small metal clamp on the cord at the base). I was told to take it off the mower to get a replacement but after removing the...
Don't remove the rivets! The whole top of the mower comes off by removing the bolts in front and back (I'm assuming it's a Briggs). Should be two up front and two in back. Pull the whole top off the blower assembly then you can replace the rope yourself. You sound pretty savvy so I'm gonna send you two video links that I love for doing this. After watching both, you should get the idea of how it's done. Best of luck to you and Happy Mowing. James
Video1: http://www.youtube.com/watch?v=GyjQir3b3xI
Video2: http://www.youtube.com/watch?v=i3ZMVFi0yqY
Aug 10, 2011 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
I pulled out the pug to recharge the starter for key start, and lost the outer plastic casing to plug it back in. Can I order the casing for the exposed prongs
The 10640 model does not have an electric start that I can see. Are you sure you have to model number correct? The 10642 and 10642C models are electric start. I will use the 10642 as a parts reference.
The electrical assembly is here:
http://www.partstree.com/parts/?lc=lawn_boy&mn=10642%2C+20in+Mulching%2FRear+Bagging+Lawn+Mower%2C+2009+%28SN+290000001-290999999%29&dn=3361337A-392215-0007
Where did you pull the wires out from? The battery box? The mower harness? The switch?
From looking at the parts available you should be able to figure out which part you need to replace.
Kelly
May 22, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawn boy mower bought used wouldnt start then the rope broke
Jun 22, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
