Question about Philips Magnavox 27MS343S 27" TV
Philips Magnovox FP5251 G104 (1995 model)...
Details: Projection TV manufactured in September 1995. The TV has a dark cast over it (watching tv or movies). I've navigated through the menu and I've been unable to solve the issue. I've searched online for the manual and that avenue was unsuccessful! Please help.
If you can remove the screen you probably need to clean the mirror. if that is the case, don't use windex use a very mild solution of dish liquid (3-4 drops to the quart) then you will have to wash it several times with that. any harsher solution will remove the mirror surface. use a very soft , lint free cloth but not terry material. your bath room mirror has the "silver on the back side this one if it glass has the "silver on the front. if it is mylar don't press hard or it will streach and distort the pix. good luck
Posted on Sep 24, 2007
SOURCE:
Why is the picture dark Magnovox FP4610W104?
If the picture is dim, the backlight is starting to fail. If the screen is black and you cannot see any picture, the backlight has failed completely.
Sep 13, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnovox FP5240 W101 color is washed out and NO brightness. has to be near dark to see picture
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Philips Magnavox 9P6034C 60" Rear...
How do you replace bulb in magnovox DLP?
Try website like You Tube.Type in ur tv model,make and projection lamp replacement.U will get a tutoring video how to replace the projection lamp.
Aug 10, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
