Question about Onkyo TX-SR875 Receiver
Repair hdmi 875 - Onkyo TX-SR875 Receiver
Invalid format
What does the error message read? sounds like the tuner board ?
Sep 06, 2012 | Onkyo TX-SR875 Receiver
No image/sound when sony ps3 is connected to onkyo 875
I've had problems with my Onkyo receiver too.
Firstly i suggest going into the Onkyo setup menu. Make sure that in "source settings" i think that's the menu option) that the input e.g. dvd is set to receive HDMI. then go into the settings for DVD and ensure that resolution is set to auto, then go into the monitor out settings (option 1 on main seyup menu) and make sure that main monitor out is set to HDMI and auto resolution.
hope this helps,
Aug 13, 2009 | Onkyo TX-SR875 Receiver
875 onkyo
Front Display Panel.
Sorry for the confusion
Oct 09, 2008 | Onkyo TX-SR875 Receiver
Onkyo TX SR 875 HDMI switching
Hello, do the receiver inputs work with other HDMI sources? Thank you, Onkyo USA
Apr 07, 2017 | Onkyo TX-SR875 Receiver
Loss of video signal from Onkyo TX SR 875
GO TO HARDWARE IN MENU SWITCH HDMI AUDIO OUT OFF, IF THIS DOSE NOT WORK MAKE SURE B SPEAKERS ARE NOT ON AS THIS PUTS THE MENU UP THE LEFT ,SOUNDS DAFT BUT IT DOES.IF YOU STILL HAVE PROBLEMS YOU HAVE A FAULT.
HOPE THIS HELPS.
CABLE GUY.
Jun 15, 2008 | Onkyo TX-SR605 Receiver
Onkyo 875 suboofer problem
decided to get a technician over.
Apr 22, 2008 | Televison & Video
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
HDMI Output with my Onkyo 875 Receiver
Hello, the TX-SR875 does not support up-converting from component or S-video to HDMI. Is the model number correct? You stated the receiver is "brand new". This model is from 2007. Thank you, Onkyo USA
Mar 23, 2017 | Onkyo TX-SR875 Receiver
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
44 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
