Question about Acer Aspire 3680 Notebook
My Acer Aspire 3680 will not power up.
It worked fine yesterday, I have a power light on when I plug into AC but pressing the power button does nothing. I do not have a battery light on, I removed and replaced the battery several time but made no difference.
Try leaving the battery out overnight. Sometimes it takes a while for the internal electronics to go 100% dead. Also, try holding down the power button for 10 seconds; that occasionally helps. Alas, it looks like you have a hardware failure, so the above may not work. Is your data backed up? If not, the drive is easy to remove and aspire 3680s are cheap on eBay.
-Guy Macon
www.guymacon.com
Posted on May 05, 2009
    Scholar:
  • 111 Answers
Sounds like it could be the power button going, I am having the same problem.on my 3680, I got an extended warranty so I will see if they can fix it, I suggest you do the same if youi can.
Posted on Apr 01, 2009
I have the same problem - only happens sometimes. When it happens, try to press the power button and leave it for a while, then it may start a few minutes later. I found when this happened and I managed to get in later, the system time (not date) always a few hours different. I suspect this is something do do with the CMOS battery failure.
Posted on Nov 27, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer 3860 no power
Contact your manufacturer for further assistance.
Jul 29, 2010 | Acer Aspire 3680-2682 Notebook
Acer 3680 won't power on even when plugged into the wall
try doing power drain by disconnecting all the cables and battery then press and hold down the power button for 1 min then , check for working if not , you need to service the system
Jul 03, 2010 | Acer Aspire 3680 Laptop
How do i fix a disc error on my acer aspire
Make sure you do not have any devices plugged in to the computer like a USB flash drive or a MMC. Usually what you have to do about that is to drain the power of the computer. Turn it off, remove the battery, unplug the AC adapter and then press the power button for 5 secs. Turn it on using the AC adapter alone. if you still get the same message, You will have to physically open the back of your laptop and reseat the Hard drive. If it still wont correct the problem, restart you computer and either press f2 or delete to enter the BIOS page. check if the HDD is properly detected and try to reload the BIOS defaults. now if any of these wont work, call ACER and most probably your Hard Drive is bad.
Jun 12, 2010 | Acer Aspire 3680 Laptop
Battery light blinks on Acer 3680 but won't boot
yes you have a problem inside your laptop.find the slot of memory then remove easy the memory then make a clean the memory then put it back again and try to but the unit.thats all...good luck and i hope its done..thanks
Jan 09, 2010 | Acer Aspire 3680 Laptop
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Blank screen on my acer aspire 3680 laptop
Sounds like you have gotten stuck in presentation mode. Hold down the function Key (Fn) its blue, and then hit the (F5) key once. If the screen doesn't come back, press both again.
May 17, 2009 | Acer Aspire 3680-2022 PC Notebook
Power button from my laptop acer aspire 3680 is broken
their are many people who sell laptop parts on eBay, I suggest looking there.
Apr 20, 2009 | Acer Aspire 3680 Laptop
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Acer aspire 3680 - new out of box won't boot
NEED TO DEL PARTIONS MAKE NEW ONES FORMATT THE HD THEN INSTALL XP AGAIN AND UPDATE
Jan 22, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Notebook Logo
780 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
