Question about Toshiba Satellite L25-S121 Notebook
My laptop does not run on fully charged, new, battery.
I want to replace or fix the internal battery connectors that I am told might be loose. This loose connection is preventing me from using my laptop on a fully charged battery.
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
How to fix acer 5735 battery not found?
Will the laptop stay on if you unplug it from the electrical outlet? Try letting the battery die completely, and then charging it fully and then switching it back on? You could also take the battery out and wipe the connectors down.
Aug 02, 2014 | Acer Aspire Computers & Internet
Dell d810 battery not charging
Instructions
Determine if the Dell Latitude D810 battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Apr 02, 2013 | Computers & Internet
Acer 5742 will not charge the battery
Before you replace the Mobo, test the battery and try another cord/charger of the exact type/power specs. If the AC jack is damaged, due to a pull, yank, tug....etc. on the cord, the AC jack may need replacing. It's difficult to say for sure, without eliminating other factor, the ones I mentioned. I assume a QUALIFIED computer tech told you the Mobo needed replacing??? Is the battery a replacement? Is the cord original?
Nov 23, 2012 | Acer Computers & Internet
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
Can't charge battery
Remove the battery and try if the PC turn on connecting to direct currrent.
If it turn on (whitout battery), the issue should be a connector problem or a damaged internal recargher.
Oct 19, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
Power source connection to my HP Pavilion dv 8000 disconnects often and connector must be reinsertd and jiggled to establish ac power supply
YOU SHOULD CHANGE THE CONNECTOR BEFORE IT BLOWS UP THE POWER IC'S THAT LINK TO THE CONNECTOR
IT'S A BIT LOOSE
Sep 12, 2009 | Computers & Internet
Battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
May 21, 2009 | Dell Vostro 1500 Notebook
If you put in fully charged battery and after taking one picture it reads battery low whats the problem
two problems either of that will be causing this. 1)either the battery is drained internally its showing up charged on the device but actually not getting charged so its happening. to resolve this replace the battery. 2)either the connector which is touching the battery internally is got loose internally so its showing up this problem. to resolve that connector problem the device must be opened and that connector should be resoldered.its a metal connector.
Feb 20, 2009 | Kodak EasyShare C310 Digital Camera
My laptop battery won't hold any charge
its the connectors to which the battery gets connected internally that r either loose or boken from internally needs replacement or a minute reparing.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite L25-S121 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
