Question about Compaq Evo N610C Notebook
Original setup was interrupted
Cannot continue with original setup. Power cord fell out during the original setup. Error message says "The system is not fully installed. Please run setup again." I click the "OK" button but it keeps giving me the same error message each time I try to reboot.
  • Dan Murphy Aug 03, 2007
    There is no choice to "resume setup". There is no option to "cancel setup & restore previous system" I chose "Last known good configuration" and the error message reads: "Windows could not start because the following file is missing or corrupt: \WINDOWS/system32\config\SYSTEM I don't have the original setup disk, or any disk.
  • Dan Murphy Aug 05, 2007
    I will need to order a setup disk from HP, which was not provided by the seller. I downloaded the HP Startup Utility, and Sysprep, and put them on separate CD's but the computer will not run them, even from the F8 and F10 menus. I hope using the setup disk works.
  • 520 Answers
Hi bud , when you turn on computer enter setup bios,select options for boot,select first boot cd,save setting and restart with your xp disk in drive.screen will say press any key to start from cd.press any key and reinstall fresh copy not repair not continue.
Posted on Feb 22, 2008
  • 883 Answers
Press F8 key (just after BIOS screen) at the next cold reboot and you will see a DOS screen with 3 or more options. Read each of them and I think you will see one option is to resume setup. This option places the system at a safe entry point to continue the setup. Another option may read "cancel setup and restore previous system"...this one may be used if you cannot get the "resume setup" option after repeated tries.
Posted on Aug 03, 2007
  • Marty marty Aug 03, 2007
    at this point, I think you must get a setup disc again, but then choose "DOS prompt only with CDROM driver installed"...and then insert CD at DOS prompt with CDROM drive letter and then type "setup". I have gone through this myself and the only way forward was to do these steps. If still dead end, then you may have to run FDISK and format C drive to start over completely. Have a startup floppy disk (create one from a good PC) on hand and ensure the following files are present: scandisk.exe, fdisk.exe, format.exe, and sys.exe. For more help, post back.
    I have also come across the option to "resume setup", but that may be because of the progress of the setup state. It appears that only this option is available after a certain stage is fulfilled...your pc may not have reached that stage yet.
SOURCE:
Can a power interrupt during hard drive installation cause a "Boot manager missing" message?
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation.
As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable.
If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive.
For that type of recovery I use gparted, which can be downloaded for free from http://gparted.org/livecd.php
Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
Mar 10, 2017 | Seagate BARRACUDA Computers & Internet
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
How do I completly reboot my hp pavilon dv6700 back to is factory settings. I have windows vista service pack2
here are some directions:
(if applicable) When the notebook is powered on, press the wireless button to turn ON the wireless switch.
Turn the power off and on to restart the computer.
Press the f11 key to launch the HP Recovery Manager. NOTE: If the HP Recovery Manager cannot access the hard drive to fix the system errors, use the personal recovery discs to recover the hard drive to its original condition.
When the Welcome to HP Recovery Manager windows displays, click Next .
When prompted to perform a Microsoft System Restore , select No , and then click Next .
When prompted to perform a System Recovery , select Yes , and then click Next .
When prompted to Backup Files , select the desired option.
When prompted to perform a Recover your computer to original factory condition , select Next and
allow the system recovery process to complete. NOTE: Do not interrupt the recovery process even
if the Windows desktop is displayed. The computer will restart automatically during the setup. Wait until the setup is complete and a prompt is displayed to login to the computer.
-http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859585&cc=us&lc=en&dlc=en&product=3636595
Nov 07, 2010 | Computers & Internet
My problem is exactly like the one chrisn569 on Dec 21, 2009 related to you. I bought Roxio Creator 2010 and it installed fine the first time but now I can't uninstall. I tried to repair it with the disc...
Running the RegCure won't help. Use RevoUninstaller to remove the entire program (Roxio) as Revouninstaller will show you all the registry entries which you can delete it very easily.
Apr 26, 2010 | Roxio Creator 2010 Full Version for PC...
My ida-x100 doesnt recognise my ipod when using the apple usb cable
I have a similar problem. The original Alpine USB cable fell apart on me and I began receiving an error message. "No, biggie," I thought. "I have plenty of iPod USB cables." But I get an error message with each one, as well as an error message with every iPod I've tried. Apparently the IDA-X100 will only read iPods if you use an original Alpine USB cable.
Sep 05, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Hp dx2000 boot problem
Hi Robert,
please try these troubleshooting steps,
Resolving the blank screen Follow the instructions below in order to fix this issue:
  1. Remove any CDs, DVDs or memory cards from the computer.
  2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected.
  3. Restart the PC. NOTE: If this resolved the issue, see the Preventing the blank screen section at the end of this document.
  4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears.
  5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER .
  6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER . The PC restarts.
  7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps.
  8. Select Safe Mode from the Windows Advanced Options Menu .
  9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue.
Jun 23, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
367 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
