Question about Celestion CSW Speaker
I have a celestion CSW powered sub that's buzzing is it worth fixing are just replace
3 Suggested Answers
SOURCE: I have a Celestion CSW Sub woofer. It powers on as
This speaker has a low frequency roll-off filter. Does your program source have low enough frequencies to pass through the filter? The effect of the subwoofer on most music is very subtle unless there is heavy bass in the source. You should try some songs that have a heavy under beat.
How are you driving the CSW -- by way of the line input or as a series connection to your full range speakers?
Posted on May 06, 2011
  • 910 Answers
SOURCE: I have a celestion s10 sub which after a house
You say you've connected it to the Left Input on the Sub. I take it from this that it also has a right Input? Is the sound the same when connected to this?
If it is then the first step would be to open the unit and look for loose connections. If these are all OK then you'll need to check for damaged / blown components on the Subs Input PCB. (Can't find a Manual so not 100% sure of the contents of the Sub)
If the PCB & Connections look OK then the next thing would be to check the speaker. Lightly press the centre of the speaker with your ear next to it and check for a grating noise. If there is a grating noise then the speech coil has either been damamged or dislodged. This can't be fixed and the speaker would need to be replaced.
Let me know if you need any further assistance once you've opened the unit and if possible some photos of the internal PCBs etc.
Posted on May 07, 2011
SW-910, blown speaker or ? makes rattle/buzz sound. replace speaker and/or change to passive type sw?
i would suggest replacing it rather than fixing. The cost of the repair will be about the same.
if you went to a passive sub/seperate power amp setup you could get a much higher quality unit, but it would cost you considerably more cash.
Feb 01, 2015 | Sony Audio Players & Recorders
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
My sub ts7 won't power on
check the cable , might be it burned bcoz of the voltage fluctations.
If not check the transformer if its buzzing or not. if not- buzzing replace the power cord
Aug 08, 2012 | Harman Kardon HKTS 7 System
PROBLEM WITH SUB WORKING ON A PIONEER VSXAX5I RECIEVER
The problem is in the powered sub, the buzzing sound is caused by one or more defective audio output ic's that drive the subwoofer directly, service is the only option to remedy the situation.
Apr 14, 2012 | Pioneer Audio Players & Recorders
How I fit the XL seat for quinny buzz. There doesn't seem to be anything to fix it onto?
Hi
The infant stage seat fabric that the Quinny Buzz was originally fitted with is on a sub seat (seat frame) that is then clipped into the chassis.
Remove the infant stage seat fabric from the sub seat and replace with the 2nd stage seat fabric.
Mar 28, 2012 | Quinny Baby Gear
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
I have a Celestion CSW Sub woofer. It powers on as the light lights up but I get no sound i checked the fuse and it seems to be great and intact. I also checked the actual driver to see if it was blown or...
Jul 13, 2010 | Celestion CSW Speaker
Cirwin vega home sub
make sure that there are not any power cords near the leads from the amp to the sub.
Jan 11, 2008 | Celestion C6-S Speaker
Switch mode power supply not switching and buzzing when powered up.
Common failure " buzzing " cause = bad flyback transformer
& horiz output transistor = replace both at same time.......
part # 's 257807 & 237470 RCA only No sub's.........T.
Oct 31, 2007 | RCA 32F530T 32" TV
29 people viewed this question
Top Celestion Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Robert Rankin
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
