Question about Bosch 7 - 1/4" Skilsaw Circular Saw
Where is the safety button on the Skilsaw Model 5275
On a skilsaw 5150, I'm just trying to see if it
Hello, No such thing as a "dumb question"... everybody learns something for the first time. The safety is a button located just behind the trigger mechanism ( about where your thumb would be during operation) and must be pushed prior to squeezing the trigger. Since it is a selling feature of any item to have an operator's manual with the item, I am attaching the link to the english version.
http://www.skileurope.com/common/manuals/_Private/5150/5150-GB.pdf
Hope this helps!AYEUH
Aug 19, 2011 | Skil Saws
How do you tighten the blade bolt on skilsaw model 5150? Thw shaft just turns and won't tighten.
There is a button on side that lock blade . Push on button turn blade by hand till you feel button engage now you can tighten bolt left hand threads
Jan 26, 2011 | Garden
Can't figure out the skilsaw 3315
PLEASE PLEASE Do Not Use this saw!! The lock is on the right side. Little black button. Press the saw down a bit an pop the button out. May have nightmares after answering! LOL
Mar 26, 2010 | Skil 10" Table Saw
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Users manual for Skilsaw model 3305
I found something on amazon, take a look here: Amazon com Skilsaw manual. I hope this was helpful. cheers
Sep 02, 2009 | Skil Saws
How to replace a guard spring on a model 367 skilsaw
take blade off and under blade there is a giude around shaft area around housing where sping goes i hope this was helpful
Aug 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
I have a Skilsaw Model 77 Type 16 and I need the power switch
i think skil was taken over by ryobi some time back
Jul 26, 2009 | Saws
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
How do I change the blade?
use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
May 08, 2009 | Saws
Bosch 7 - 1/4" Skilsaw Circular Saw Logo
153 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
