Question about Kenmore Washing Machines
How to replace water inlet valve w10144820 - Kenmore Washing Machines
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
jsrock516
  • 5911 Answers
SOURCE: water inlet valve Kenmore dishwasher
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Posted on Jul 09, 2008
  • 130 Answers
SOURCE: My Neptune washer is leaking water from underneath.
Yes they are the same.
Posted on Jan 26, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 90 series need to replace the inlet valve
This is actually a simple repair that the average Do-It-Yourselfer can perform with just a little guidance. The following link explains all the steps necessary to replace a water inlet valve on a Kenmore top loader:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If you have questions along the way, please let me know. A replacement valve can be purchased online at searspartsdirect.com, appliancepartspros.com, repairclinic.com, or pcappliancerepair.com. All these sites offer competitive pricing and excellent service, so shop all of them for the best price. Use your model number for your search criteria. If you do not wish to order on line, use the part number found at the sears or appliancepartpros website and go to your nearest appliance parts retailer. This is a part that is commonly carried as part of the in store inventory. I hope this helps you.
Posted on May 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Hoover Premier 710: which inlet valve to buy?
It appears your single inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Fault 49 pops up on the screen
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
Mar 09, 2016 | Washing Machines
Changing water soinoid
http://www.youtube.com/watch?v=Fk4puRv3Vk8
this isn't for your valve but will show you how to get at it,your valve is a w10144820,Use a flat blade screw driver and remove the plastic mounting pin, and disconnect the tabs in the assembly from the slots in the cabinet back, disconnect the wires and reverse the procedure to install the new valve assembly. hope this helps.
Apr 06, 2013 | Whirlpool Washing Machines
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
No fault code washer will not fill
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool WTW6400SW Cabrio Washer
Roper RTW4305VQ washer has only cold water. No hot water will come out. We have cleaned the screen from the hose and inlet already any ideas on what could be wrong?
That water inlet valve where the screens are that you cleaned is bad and needs to be replaced. The part# is W10144820 it could be purchased from your local appliance parts store or online at;
apdepot.com
assuredparts.com
repairclinic.com
This video will show you how to take apart the machine to replace that inlet valve.... Gene aka old tech2332
Aug 11, 2011 | Washing Machines
Water not entering washer
Hi
Daniel
Aug 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
Dishes not coming clean
Check water inlet valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
How to test a dishwasher water inlet valve.
How to replace a dishwasher water inlet valve.
May 26, 2011 | Maytag Dishwashers
Water does not shut off. Water flows constantly
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Aug 29, 2009 | GE WBVH6240F Front Load Washer
The cold water will not run.
Aug 24, 2009 | Maytag MHWE300VW Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
