Question about Briggs & Stratton 15,000 Watt Home Standby Generator
Stops and starts
My briggs and stratton 7000 watt propane generator keeps starting and sopping for no reason. Can someone tell me why?
  • Anonymous Mar 25, 2014
    7000 watts
  • 169 Answers
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Posted on Mar 15, 2009
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
May 19, 2013 | Briggs & Stratton Power Products 5,550...
I have a Briggs and Stratton 7KW standby generator. I accidentally spilled some oil on it during a hurricane and cleaned it. However, when I try to start it, it will go on for about 15 seconds and then...
sounds more like a fuel problem not oil being spilled on it but check the oil level some have a low oil shut off see if you can keep it running spraying carb cleaner in the air filter that will tell you if it is a fuel problem more so a fuel problem if you left fuel in it for more than 30 days
Aug 14, 2012 | Briggs & Stratton 15,000 Watt Home Standby...
Can not start engine
There is air in the line and some times thaey have a primer button on the line near the generator.
Jan 30, 2012 | Briggs Stratton 7,000 Watt Automatic Home...
Cleaned carb installed new gaskets jets were clean dont know what the idle or mixture screws are set at to get it started (recoil start) turned them to 1and a 1/2 no luck
i usually set the idle screws to 3 turn then adjust to fit. it hasnt faid me yet with the three turns. turn all the way in and when it stops turn out three complete turns of tool on hi side and low.
Jul 10, 2011 | Briggs & Stratton Briggs and Stratton...
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
May 01, 2011 | Briggs & Stratton Briggs and Stratton...
My 7000 watt stand by gen. did not start when the elec. went out. It can be started both manually and on auto but only runs for about a minute then shuts off. It has propane and the oil is okay. What...
Check the Filter. If clogged it will not start. Also drain the fuel and inspect it. If the mix is off or if there is oil in it when there shouldn't be then that could be the problem.
Mar 19, 2011 | Briggs & Stratton Electrical Supplies
I have a Briggs and Stratton 7000 watt propane generator. When running this morning after two hours, it quit. It starts back up for about three seconds or so then quits again. I put a new tank on...
does this engine have a low oil shutdown unit on it
if so check the oil level an top it up it could be interupting ignition
be sure your tanks are full and connections are good and tight
brush soapy water around connections to see if any have a leak
if not oil level shutdown , then sounds like a fuel problem
suggest have a gas serviceman take a look
these units can be tricky to solve
Aug 11, 2010 | Briggs & Stratton 15,000 Watt Home Standby...
My propane generator engine has apark and gas
For a quick test.
Check engine oil.
Remove wire from low oil sensor and see if it starts every time.
If that works change oil and replace low oil sensor.
Hope this tip helps to solve your problem.
r/
David
Jan 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 15,000 Watt Home Standby Generator Logo
581 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
