Question about Dirt Devil Featherlight Bagless Upright Vacuum
Dirt Devil Featherlite - how to remove the beater bar to clean
Could someone please tell me how to take the base apart so I can remove the beater bar to clean it. This is an upright. I can't seem to see how to take it apart and do not want to break it.
Thank you for any help
  • Anonymous Mar 24, 2014
    belt broke, removed beater bar and cleaned off all the hair that was wrapped around it, put new belt on and within the 1st 20 seconds the new belt broke. the beater bar is very hard to rotate. what should I do?
If you lay it down and look under the base- by the brush roll- there are three screws you have to remove w/ a philips head screwdriver to get the base plate off. From there you can take out the brush roll, etc.
Posted on Mar 15, 2009
  • 76 Answers
Look in the owners manual on how to replace the belt. it should explain how to take out the brushroll
Posted on Aug 22, 2009
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Jun 19, 2017 | Bissell 6594 PowerForce Bagless Upright...
Tip
Burning rubber smell from your vacuum?
Drive belt is slipping.
Remover cover from the bottom of the power head or base if upright style. Usually just 2 to 4 screws.
You will see a belt (thick rubber band) connecting the beater bar (roller with brushes) to the motor. Remove the beater bar and belt. You do not need to remove the motor. The beater bar will be held by clamps and screws. Remove the screws and clamps and lift the beater bar directly up.
Take the belt to your local vacuum dealer (note make and model) and get a replacement.
Installation is the reverse of removal.
Note: you will find a lot of hair and junk twisted around the beater bar. Take the time now to cut it all off.
Hope this helped. Please rate this if it helped you.
on Mar 07, 2010 | Vacuums
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
How can I tell if I need to replace the beater bar? I replaced the belt but now it seems too tight and the bar doesn't want to spin.
The belt is supposed to be tight, but the beater bar bearings are probably full of string, hair, and thread. Remove the bar, remove, clean, and oil the bearings (3-1 or similar). Leave the belt off for a moment, and install just the bar. Spin it with your fingers--it should revolve freely--if not, redo the clean/lube process again making sure to clean the inside of the bearings with a Q-tip swab. Once the bar spins freely, remove it to slide on the belt and reinstall. Hope this helps!
Oct 16, 2010 | Bissell 6594 PowerForce Bagless Upright...
Hi, The belt of our Dirt devil bagless vaccum broke and we got new belt and replaced it. Even after replacing the belt, the brush is not rotating. Any suggestions please ?
Did you check to see that the beater brush, the brush that the belt drives, is free of debris and moves freely? When they bind up they can cause the belt to break. Remove the beater brush just as you do when changing the belt and clean as best you can. There are retainer clips at each end of the brush, add some WD40 between the clips and the beater brush and turn by hand to free it up. Reassemble making sure the belt is on in the proper manner so that the brush will turn in the correct direction. If you find this solution helpful, I would appreciate a Thumbs Up from you!
Thank you. Paul
Oct 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The rubber belts I put on keeps burning when I first put it on, it gets so hot on the metal bar I hook it to, that it splits it it two..how do I fix this???
Sounds like the beater bar is clogged with something. Try removing it and cleaning it up, sometimes hair gets wrapped around it and puts it in such a bind that it will burn the belt.
Jul 03, 2010 | Dirt Devil Featherlite Bagless Vacuum...
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
The hand cleaner picks up dirt but the floor cleaner does not.
A couple ideas.
1. Have you emptied your dirt?
2. Are your filters clean?
3. Is your roller brush working and if not, is your belt broken?
Hope this helps and good luck!
Mar 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Smell smoke , belt is on
sounds like you have the same problem i do the beater bar isnt moving and causing the belt to burn
Feb 18, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Featherlight Bagless Upright Vacuum Logo
389 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
