Question about Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT
09 gti code p2432 - Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT
Codes p2432/po234/po106
Hi. I would check for an air inlet system leak. I suggest a pressure smoke test.
Jan 18, 2014 | 2002 Volkswagen Golf
P2432
Hello, guys. Here is a complete diagnostic fault code table for your refer. And you can try some OBD2 scanner to clear the code, for example, vchecker v302 is liked by many peoples.
Sep 09, 2012 | Cars & Trucks
I have a 2007 Chevrolet Trailblazer we have replace the secondary air injection pump and relay and the check engine light is still on. We have cleared the computer but comes back on after next start up....
P2432 secondary air injector system pressure Sensor circuit low. Have you check the air control solenoid valve itself? Also look for obstruction. It is listed as number 1 in the fiqure.10_2_2011_3_30_28_am.gif
Oct 01, 2011 | 2004 Chevrolet TrailBlazer
Codep2433 and code p2432 were diagnosed. i repaired both the code issues however my check engine light stays on still
unhook the battery for 30 minutes , and then hook it back up,, this should make the computer go through its mode and rest ,, if not, you'll have to take it in to be rest
May 04, 2011 | 2005 Pontiac Grand Prix
What phones are compatible with an 09 golf gti car kit
i really dont no mabey the blackberry storm the lg dare look it up on wikiansers
Dec 01, 2009 | Car Audio & Video
HAVE A 2005 CHEVY TRAILBLAZER WITH P2432 CODE ?
Yhea it's under the truck on drivers side bolted to the transmisson crossmember. There are three 13mm headed bolts holding it on, they go up through the crossmember and bolt to the bottom of the bracket that is holding the air pump on. there are two hoses going to the pump that you need to take off and two electrical connectors. Then you will need to switch a few things over after you get the old one out. Not hard at all, Becarful when pulling the hoses off most of the time the reason they fail is because water has gotten in there, when you take the hoses off you get soaked(i speak from lots of unexpected showers).
Oct 17, 2009 | 2006 Chevrolet Trailblazer
Getting ETC p2181 code for vw gti 1.8 t 02
punch one code at a time into google search check related symptoms
Sep 12, 2009 | 2002 Volkswagen GTI
Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT Logo
107 people viewed this question
Top Haynes Heating & Cooling Experts
Mike
SimplyNo
Lawrence Oravetz
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
