Question about Lands Phones
Ids 816 alarm panel keypad goes dead - Lands Phones
Dsc 9047 wireless alarm, had multiple sensor trouble, panel does not seem to recognize any wireless points, almost like wireless function has failed in keypad. Is this possible and is there a way to...
Chis power cycle system wait 60 seconds and try to see if points come back.Either your receiver is bad or your wireless points batteries are dead or somehow the wireless points got unlearned
Nov 02, 2013 | DSC 9047 Wireless Security Alarm Kit -...
Ids 816 alarm system problems
My indicator lights are not working on my control panel eg, power light etc, yet all the numbered keys are lit up. When I take the plug out the wall then the whole control panel does not work, need help please, I am not currently able to arm the alarm.
Apr 25, 2013 | Home Security
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
I have 3 ademco keypads on my system. The system came with the house that we bought, when we moved in, all 3 keypads have no text on the screen. The main keypad by the front door will beep and say...
This means that the alarm panel's backup battery is either bad or not connected. These batteries provide power for the system in case of a power outage and are essential for a solid alarm system. Look inside your control panel box ( usually in the master bedroom closet ) and see if the battery connection is just off or if the battery is missing. If it is connected, it is probably too old and needs replacement. Contact your local alarm company and they can swap out your battery or provide one for you.
Jan 17, 2011 | Honeywell Vista 20P Alarm System Kit with...
The phone is making a quick ring ring ring ring sound continually it is like it's frozen just ringing
quick solution, unplug the phone from the wall leave a minute, then plug back in. if an Alarm has been set this would in MMC 114, I have sent you a video explaining Alarm mode on the Prostar 816. or go to http://www.abbeytelecom.com for written copy.
Apr 05, 2010 | Samsung Prostar 816 Phone
Keypad keyless entry code missing
Ford has an add on keypad also if it is pretty much flush on the door it is factory if it is a fat keypad it is an add on The factory module is under the dash by the fuse panel the number should be on it
Oct 15, 2008 | 2006 Ford F 350 Super Duty
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
Mar 19, 2008 | Samsung Prostar 816 Phone
Alarm trouble
OC means a wiring problem between the keypad and the alarm. Take the keypad and hook it up in the alarm cabinet and see if it works there.
Jan 22, 2008 | Cisco Alarm Expansion Panel (15454-AEP)...
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
