Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
Where is the reset button
Product makes a buzzing sound.
  • Curt Diemer
    Curt Diemer Mar 25, 2009
    buzzing like it is jammed but the blade turns freely. It is only a couple years old Insinkerator.
  • 478 Answers
On the bottom, its red.
Posted on Mar 12, 2009
LG washing machine will not spin just makes a click sound an buzzes? any help?
any error codes, make and model no. would help.
some swear that unplugging and waiting a moment and plugging back in will reset. some say, doing same and holding in start button while unplugged for 10 seconds will reset. not sure about those, but pretty easy to try.
Oct 05, 2015 | LG Washing Machines
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Dishwasher dishes cloudy and makes loud buzzing soundf
I am not sure about the buzzing but cloudy dishes is caused by
hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 03, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Scanner failure
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
call in to hp at 1800-474-6836 and since this is a hardware issue directly tell the agent you would like an upgrade if you decide to get it.
It will have a 50% discount on the upgrade printer for you with hardware and software covered by a one year warranty which you can extend upto 3 years on the spot
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Kenmore gas stove makes a buzzing sound
Is the door locked?? Is it an electronic buzzer sound??
hold the CLEAR button for 3 seconds - the door will unlock.
open the door - and press CLEAR for 3 seconds.
Error code may come up.... close and re-open the door.
Are there any indications on the display?
Or is this a mechanical buzzing from underneath? in this case your gas regulator's diaphragm has failed.
If the above reset doesnt wokr (and the sound is electric) your circuit board will need replacement.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 09, 2009 | Kenmore Kitchen Ranges
IR T 20 air compressor will not kick on
IS IT THREE PHASE OR SINGLE PHASE? MOTOR TAG WILL SAY PH 1 OR PH 3.DOUBLE BREAKER OR TRIPLE BREAKER WILL ALSO TELL. IS THIS A BRAND NEW INSTALL OR AN EXISTING COMPRESSOR THAT JUST NOW STARTED DOING THIS. SOUNDS LIKE A POWER PROBLEM LIKE A MISSING PHASE OR BLOWN FUSE. REMOVE FUSES WHEN OHM CHECKING - DONT TEST THEM WHILE STILL INSTALLED.
Mar 14, 2009 | Air Tools & Compressors
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
312 people viewed this question
Top Buck Home Experts
Gene Haynes
salaberrios
salaberrios
Level 1 Expert
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
