Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Remove glass from hp 8500 scanner - HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
2 Suggested Answers
SOURCE: Haze on INSIDE of HP 2610 AIO scanner glass - how to remove glass?
with the 2610, on the right side remove gently the coverplate and then slide the under panel down. There are four places it attaches to the printer case one at each corner approximately. you can try to do what I did and use a greenie flathead screwdriver to pry it free, or do the not so obvious but much easier and kinder to the machine version of pushing it down to get the L shaped plastic pieces to release from the upside down L underneath. then there are three size T10 hex or star shaped screwdriver screws to release three of the four sides. I never could get the front silver fitted piece off, but was able to remove the glass. DO NOT CLEAN WITH WINDEX...IT LEAVES RESIDUE. USE VINEGAR. ALSO, USE WHITE GLOVES AS any dust you get on it cleaning it will leave small fibers on both sides. I used a special glass cleaning rag and then gently replaced it. note which side the black strip goes when you remove the glass!
Posted on Jan 03, 2008
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 has a line on scanned copies. How do I get rid of the line
check the scanner glass, run your nail over it as you may not see it as they may be a small amount of tipex on the scanner glass
Mar 23, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
How to removed error E000202-0000 for ir 5800
unplug the copier .remove copyboard glass,slide scanner towards right side, under copyboard glass on left side rear corner there is a black sensor which will look the shape( 'F'-side view) clean the cavity between two horizontal arms of 'F' shape sensor with a soft painting brush(10 mm).replace copyboard glass ,swich on the machine.
Jan 21, 2011 | Canon imageRUNNER 8500 Copier
Problem for HP Color LaserJet 8500 Printer Black line on the left side printed page while making copy on HP. This problem occurs only while loading the page on the top tray HP 8500 printer. No black line...
This is usually caused by something on the scanner glass. Check for dried ink or correction fluid on the scanner glass. We have a short article about solving this type of issue posted here: http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | HP LaserJet 8500 Color Printer
My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 23, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 - issue scan & copy
while the printer is on take a damp cloth and wipe the scanner glass and then open the automatic document feeder and clean the scanner glass there and then remove the cartridges and close down the printer now just pull out the power cable from the back of the product and if possible and the walljack wait for 30 secs and replug the printer first to the walljack and then to the printer,now try to scan....(if your printer is wireless then after the above you will have to run the wireless setup wizard again).if that doesn't work,try the same above but just before plugging the printer cable press and hold the power button,if that doesn't work do the same holding the #3 buttons,if this doesn't work then do the same holding down the #6 buttons,if even this doesn't work then call in to hp at 1800-474-6836 and get a replacement
Oct 03, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Thick line when goes throught auto feeder
The automatic feeder passes the page over the scanner, the scanner does move, so even a small mark (often find it is correction fluid) will effect the whole page, check the glass on the left side of the scanner for any sort of mark
Sep 08, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
