Question about Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509
Battery reconditioning mode - Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509
What is the error code f03 on the vector 1092 bettery charger
F03 - Sulfate or Unchargeable Battery
Appears when the battery is highly sulfated and cannot accept normal charge current.
• Follow the steps in "Recondition Mode" to recondition the battery.
• Follow the steps in "Equalizing" to equalize the battery.
• If the situation persists after reconditioning and equalizing, we recommend taking your battery to a certified automotive service center for evaluation
Aug 17, 2016 | Vector Camping, Backpacking & Hiking
I purchased a used volvo with a reconditioned radio now the radio displays "input code" after changing the battery. how do i get a code for a reconditioned radio?
i think this is located in the user manual for the radio IF there is one, otherwise you can search for one on google
Oct 27, 2012 | 2000 Volvo S40
Battery won't charge. sometimes if you put something to hold plug up it will charge but will eventually stop after a few minutes.
Recondition the battery and try again! The steps to recondition are available on line! Let me know if you need help?
Sep 03, 2011 | Toshiba Satellite L455D-S5976 Notebook
How long and how to reconditioning the battery
the battery can only be reconditioned if it is not working properly due to a scale build up on the plates of the battery, if a cell is shorted out ,it will have no effect to "recondition it" . if a battery needs to be reconditioned to work properly it is probably close to the end of its life cycle and it will be a temperary fix
Feb 22, 2011 | Vector Black And Decker High Frequency...
My laptop says 100% charged , But when I unplug it , it only stays on for about a minute the powers down?
your battery has worn out this happens over time. you can get a battery reconditioning program to boost the battery life do a recondition every month
Aug 23, 2010 | HP Pavilion dv6000z Notebook
Batteries wont charge at all both lights blink signifying "malfunction"... wtf???
Batteries need reconditioning, but likely they need to be replaced if not new. If new, the charger may not be working.
Feb 07, 2010 | Ridgid ZRR82007 Factory-Reconditioned 12V...
3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Oct 05, 2009 | Symbol LS 4278 Barcode Scanner
Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509 Logo
46 people viewed this question
Top Stanley Black & Decker Car Audio & Video Experts
xxxxxx xxx
Are you a Stanley Black & Decker Car Audio and Video Expert? Answer questions, earn points and help others
