Question about Baby Gear
Instructions for delta double swing and seesaw
2 Suggested Answers
waynepwelker
  • 25 Answers
SOURCE: manual delta double swing and seesaw
Put bolt "A" into hole "B", repeat until complete.
Posted on Jun 27, 2012
What are the Assembly instructions delta Princess bows & laces 4 in 1 crib?
Delta Cribs manufacturer puts the conversion instructions on the bottom side of the flat board that fits under the mattress. Remove the mattress, flip over the flat board, and the instructions are there!
Jun 15, 2014 | Summer Infant Delta Childrens Products -...
How to boost my mifi 220 signal
Since your signal goes up and down, I would suggest buying a large ham radio antenna, about 15 foot, and mounting it on a seesaw. On one end put a large automotive spring, and on the other end put your antenna. Then attach a very long copper stereo wire from the ham antenna directly to the mifi unit.
When you signal starts to go up and down, you can counter it by going out and starting the seesaw. Once it hits the spring, it will go back up and then return and so on. Your signal will still go up and down, but the seesaw action will counter the up and down motion.
That should improve your signal and be steady year round unless you get a large snow storm and your seesaw is weighted down by lots of snow. In that case, you will need to shovel the snow periodically, but you will have your mifi signal back to normal.
Nov 25, 2012 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Manual delta double swing and seesaw
Jun 27, 2012 | Saws
The single handle Delta kitchen faucet is very hard to swing back & forth. I was told by your company representaive that it needed O rings. The O rings have been sent to me, however no instructions...
remove the handle that turns water on and off , usually an allen wrench lift and swing back and forth at the same time. the spigot should come off. replace o rings lubricate with silicone grease reinstall spigot and handle
Oct 21, 2017 | Delta Faucet Plumbing
How install driver delta66 in Ubuntu ?
The Delta 66 uses the Envy 24 chip which is recognized by the ALSA driver in most Linux distros including Ubuntu automatically. There's no driver to install, because it's already in the the ALSA driver. Open up the ALSA mixer setup your output settings and you're good to go.
Sep 25, 2010 | M-Audio Delta 66 Sound Card
Need instructions to Delta Jordan Crib Style # 4887-1
im trying to put together a delta jordan 5-1 crib i need to know where to start the instructions aren't clear enough
Aug 04, 2009 | Delta Enterprise Baby Gear
Swing arm too loose
What I have doen in the past is to take the compression nut off. Wrap teflon plumbing thread tape around and between the two o rings and tinghened the compression nut back down,tightening the worn swing arm joint.
Mar 11, 2009 | Delta 16955-SSSD Stainless Steel Victorian...
Instructions for the installation of a Delta 470
Here is the owners manual and installation instructions for your particular faucet:
Delta 470
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta Model 470: Signature Kitchen...
Need Replacement Parts
called 800-377-3777 and promptly spoke with a customer service representative who courtesly told me the necessary information required from the crib mattress base in order to purchase replacement parts. There was no hassle. FYI in order to get replacement pts,, you need crib model, order date, where manufactured, part numbers (all on the base of crib). Thank you so much for your assistance.
Jan 20, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Baby Gear Logo
163 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
