Question about Maytag MSD2542VE Side by Side Refrigerator
New Maytag Refrigerator drains water into a pan underneath
Maytag Frig model MSD2542VEW - just bought it...
Every so often it seems to drain water in spurts into a white pan that is on the freezer side of the unit. The pan appears to get about half full of water, and it appears to drain some but leaves some standing water. WHat is this process and is it normal?
  • 478 Answers
Check for clogged drain line bottom of inside of the freezer,or you can check it at back side underneath
Posted on Mar 12, 2009
My frig is a GED, bought in 2002. every once in a while, I will find a puddle of water underneath it - near the back left (facing the frig). I have now turned off the water supply from the wall, and for...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Maytag MZD2766GES Side by Side...
Water is leaking out of my kenmore bottom freezer frig model 76253702. I want to empty the drain pan. Where do I find it? I Already took off the front grill but don't see the drain pan. And how should...
Leo Ponder
imufo2
Aug 15, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Every Couple of Days water leaks out from under the freezer. I bought it from Home Depot about 2 months ago. What do I do now?
every 8 hours of cooling ( compressor run time ) which may be every cople of days the frig has a auto defrost . your unit may use a a d control so it may do it an any time it decides to defrost . when defrosting the water goes through a drain and under the frig to a holding pan . if pan is cracked or if drain hose is not in the pan it would leak .. it should be under warranty so i would call maytag and im shure they will correct the problem .. mope this helps mm ..majic **** ...
Oct 22, 2010 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water in refrigerator and excessive condensation on bottles
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
May 21, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Good afternoon........ I have a top mount frig.. we bought it in 1998. The frig works great..... The only problem we have is water seems to built up on the inside bottom of the frig.... I know it is not...
Hi Dan,
It sounds like you have a defrost drain issue. An annoyance to say the least. To repair you will need to clear the defrost drain as it can get a build up over a few years of use. On a top freezer model you will need to unload the freezer and remove the back panel, be sure the power is disconnected by unplugging the refrigerator.
With the back panel off you will see a set of coils that resemble a radiator in a car, below that coil is a pan that slopes to a hole the size of a dime, you may not be able to see that hole due to the ice build up. Clear the ice with hot water and towels to clean up the mess. Careful not to use anything sharp or damage the coil.
Once the ice is gone use a turkey baster to flush hot water down that dime sized hole until it flows clear, you will know when it is.
Reassemble and enjoy a water free frig.
Apr 18, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag MSD2542VE Side by Side Refrigerator Logo
418 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
