Question about Refrigerators
Ge Artica psc25nstass refrigerator freezing
The temp is cold enough but digital temp readout reads 55. The unit continues to run.
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 09, 2009
fixyourboard
  • 310 Answers
SOURCE: Ge Artica Refrigerator PSC23PSTA ss not cooling or
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
Posted on Jun 22, 2010
heatman101
  • 43501 Answers
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Posted on Sep 29, 2010
  • 2006 Answers
SOURCE: GE Artica PSS25MGMB Stopped cooling/freezing, everything else works,lights, fans, just no cold and no compressor start sounds?
I would suspect the start relay and capacitor! With the clicks and buzzes, that is the most likely fault. Although you could replace one or the other of them, I always replace as a mated pair, because it seems that when one of them fails, the other one will fail shortly after. Items 733 and 734 on the following schematic (which also gives you an idea of what they look like and where they are located)
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSS25MGMBBB/0432/0165000/G1090005/00009?blt=06&prst=&shdMod=
Posted on Jan 13, 2012
spyder301975
  • 101 Answers
SOURCE: GE Profile Artica Refrigerator model # PSC25NSTASS: control board shows 58 degress in the refrigerator but water is freezing in filter and milk is freezing, technicians have replaced the motherboard a
Bad damper in fresh food side. Door breaks causeing cold air to flow constantly into fridge
Posted on Oct 18, 2012
We have a ge profile Artica, refrigerator side too cold. Keeps resetting temp to 27 degrees. Freezing everything.
Unplug for 20 seconds & plug back in... if keeps happening, replace the front panel controller.
Feb 21, 2015 | GE Refrigerators
Ge profile artica model PSC23SGPA Side by Side not keeping temp - lost everything in freezer and now frig is heating up. Can change temp to 0 but within a few seconds reads 24 (temp set does not hold)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge artica model number pss25ngma the refer part freezes evertyhing. I have adjusted the temp but it goes back to 32 waht can I do?
check the evaporator fan; listen to see if it is running check the baffles between the freezer and, the refrigerator box for air flow. Check the control knob to see if it is turning the cold control shaft. If these are not the problem: replace the cold control
Mar 17, 2010 | GE Profile Arctica Stainless Steel Top...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Apr 09, 2009 | Refrigerators
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Everything in the refrigerator is freezing
The 37 degree reading you're seeing is the temp. setting, not the present actual temp. When it jumps back to 22-25 its telling you what the actual temp is inside the refrig....simply wait about 24 hours. It should then read about 37...that is, the temp you set it at 24 hours previously.
Nov 23, 2008 | GE Profile PFS22 33" Artica French Door...
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
